Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro Home COlor COmputer | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2017-04-18 |
Less is more, less complexity, more fun is the driving force behind the Rhococo Retro Home COlor Computer. It will be a remake home-computer inspired on the Sinclair spectrum, Initially I considered not basing it on a Z80, but on an ARM7TDMI based simple micro-controller, (probably an STR710FZ2) running at 66MHz with 256 + 16 KB internal fast Flash and with 64K internal fast RAM and a separate external 32K VRAM. But early 2017 I changed my mind, as you can read below.
It will be capable of 320x200 VGA full high resolution graphics 16 colour display (Mode "D" timings, 70Hz, Horizontal Sync = 31.778 KHz, pixel clock 25.175 MHz).
It will be a "turn on and use" system, meaning that the "OS", and a programming language will permanently reside in ROM, ready the moment you turn the Rhococo on (Meaning it will be based on some kind of interpretative language).
For the moment (quarter 4 2015) the Rhococo has been stalled, as I have problems getting the ZX81+34 ZX81 clone to work. Now working on version two.
April 18, 2017 Changed my mind, will try to build a color Z80 more "home computer" like design with a CRTC not software driven
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9916 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but thats too RETRO even for me. Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer.
