ZX81plus38 simple to build ZX-81 clone
Project ZX81plus38 | |
Most people I showed my ZX-81 clone (ZX81+35) said they liked it, but with such a tiny board and with so many "difficult" surface mount components, they doubted whether they would be able to build this kit, so I restarted my effort, to try to build a 100% compatible ZX-81 clone that anybody could build, with commonly available pin-through-hole parts. | |
Contact | mahjongg |
Last Update | 2020-10-06 |
P.S. No I won't!
October 1, 2019 continued
January 28, 2020
February 12, 2020
February 19, 2020
February 26, 2020
March 4, 2020 layout finished
and this is the bottom layer:
and bottom view
March 16, RefSpace is closed!
The jumpers are:
and bottom:
my GitHub page is here: [2]
I managed to work from home
Various people are building mij ZX-81plus38, and offer a great help debugging it
There is a forum ZX-81+38 forum on microcontroller.net specifically about building the ZX-81+38, where various people are building my clone, and they managed to find various problems, and requests for the improvement of my design. Therefore I will create version 1.5 of my ZX-81 clone (or as they state, not a "clone" as that implies simply a copy, with an ULA socket, but rather a re-implementation of the ZX-81. (I will still keep calling it a ZX-81 clone, because what's in a word). I will keep you all informed.
