Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro Home COlor COmputer | |
A brand new 8-bit homecomputer with modern parts. Above picture is just an artist impression, its probably not how it will look. | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2018-05-28 |
April 18, 2017 Changed my mind, will try to build a Z80 based more "home computer like design", with a CRTC, and not software driven
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
Ik denk dat ik eerst maar eens de $4 4-chip Z80 homemade computer ga nabouwen, en daarmee ga experimenteren. This is its schematic: File:Z80 with AVR schematic.pdf
Some thoughts
Colors of wires are:
Thick Red, +5V
Red, Databus
Yellow, lower 8 address lines
Green, Higher 8 address lines
Blue, control signals
I realized that with all the functionality I wanted to implement, while maybe I could do most of it with an ATMega chip, it wouldn't be fun, and I expected it would become a hassle to implement video and sound, the way I wanted. And that was the main reason the project stalled for almost half a year.
I had dabbled a bit previously with a unique chip, (the P832A AKA Parallax Propeller) which I suspected could be exactly what I needed. With its unique concept of using eight 32-bit cores, (called "cogs") that can each be programmed individually with either a high-level object-based language called SPIN, or with its own assembler language, and with each core having control of four 8-bit I/O ports.
Anyway, for the moment I ignored the problem, and made a conceptual drawing of RHOCOCCO where I replaced the ATMega CPU with a Propeller, here is the new schematic: File:RHOCOCO with propeller.pdf.
Via Z80 I/O and specially written routines, I should be able to access all of the Z80's RAM, so I can upload code. As a basis the rhococco should be a bit like a sinclair spectrum, TRS-80 or MSX.
I found a way to write boot code into the Z80's RAM, using a propeller chip here: http://www.shaels.net/index.php/mini80/mini80-general/119-mini8o-overview With the schematic here: File:Mini80b.pdf
it works like this:
