Designing the RhoCoCo Retro Home COlor COmputer hardware
Project Rhococo Retro Home COlor COmputer | |
Een nieuwe 8-bit homecomputer met moderne onderdelen | |
Status | Initializing |
Contact | Mahjongg |
Last Update | 2017-04-23 |
It will be capable of 320x200 VGA full high resolution graphics 16 colour display (Mode "D" timings, 70Hz, Horizontal Sync = 31.778 KHz, pixel clock 25.175 MHz).
It will be a "turn on and use" system, meaning that the "OS", and a programming language will permanently reside in ROM, ready the moment you turn the Rhococo on (Meaning it will be based on some kind of interpretative language).
For the moment (quarter 4 2015) the Rhococo has been stalled, as I have problems getting the ZX81+34 ZX81 clone to work. Now working on version two.
April 18, 2017 Changed my mind, will try to build a Z80 based more "home computer like design", with a CRTC, and not software driven
After a year or so contemplating this idea of a new homecomputer, I came to the conclusion that an ARM based system with software VGA generation might be too complex for a the simple system I have in mind. I will make a NEW homecomputer design with components that can be bought in 2017 (and the next few decades). It will be based on a Z80 compatible CPU as it is one of the few 8-bit CPU's that is still relatively easy to get, and it was so popular in the 80's that there is a plethora of software available for them. One thing I don't want is to use an FPGA for it, as these are still relatively expensive and difficult to program for. This does cause a problem, as most old homecomputers either used some kind of programmable logic (Sinclairs ULA logic) or were based around a CRTC like the MC6845 which are no longer available, or they used a VDC (video display controller) like the TMS9918 (MSX an many others) which are also no longer available. My preference would have been using a CRTC, but as I said I can find no CRTC's for sale anymore, I could build one with standard logic (like the TRS-80 did) but that's too RETRO even for me, (uses far too much components). Instead I'm wondering if I can replace the CRTC with an simple AT-mega (Arduino) microcomputer. For a 320 x 200 display you would need 320 / 8 = 40 8-pixel wide rows and 200 lines, which means you need 40 * 200 = 8000 address locations, this is about 8191 or 2 ^ 13, meaning you need 13 address lines to address these 8191 (or hex 0x1FFF) locations. and a couple of other signals like HSYNC and VSYNC and video clock. An Arduino (nano) uses an ATmega328, and doesn't really have that many GPO (output) ports, but that can be solved with a few 8-bit latches. I'm planning to do this in little steps, so first I'm planning to connect 8K Byte SRAM (or an EPROM for testing) to an Arduino nano, plus a shift register to clock out a video stream, to try to generate a 320 x 200 (monochrome) VGA signal, using a Arduino nano as a CRTC surrogate. Then continue from there.
I have looked (googled) a bit around if others had tried to combine a Z80 with an Arduino (ATMega328 chip), and found this https://hackaday.io/project/19000-a-4-4ics-z80-homemade-computer-on-breadboard which isn't exactly what I want but seems to prove you can control a Z80 from an ATMega328, and do such things as catching I/O requests, and take over the Z80 bus to "fake" data being read from "ROM", but I guessing I could also use this method filling RAM with Z80 bootable content, (when adding an 328 controlled counter for the address bus) then boot the Z80 from RAM, and I can foresee that many other technical tricks can be pulled, like creating VGA color video this way. In any case I think that the ability to use the ATMega328 as a virtual Z80 peripheral is very promising.
I also looked at other small Z80 systems, but they all are quite primitive IMHO and use things like bit banging to access I/O devices like serial ports, PS/2 keyboards and SD-cards, which is in my view a wrong approach as it uses Z80 CPU cycles too much, for things that a ATMega328 could do more easily with virtual I/O.
The fact that you can use just a Z80, a 64K SRAM chip and an Arduino to create a $4 CP/M capable machine is exhilarating, but I have set my goal on a color capable SBC that can be used with most (VGA) monitors, and has a built in keyboard, can run BASIC and has a clear architecture, and is cheap to reproduce.
