LoraWanDustSensor
| Last Update | 2020-06-22 |
The concept
The concept consists of:
- a forwarder application that collects the data from TTN and forwards it to luftdaten.info, opensensemap, mycayenne dashboard, etc.
- Apeldoorn-in-data
- (others...)
- you flash the node with a unified firmware
- the node shows its unique Device EUI on the OLED
- at the TTN console, you register the node with the unique Device EUI
- the sensor node receives encryption keys over the air automatically
- done!
- select a more sensible set of pins for the SDS011 and the BME280
- test BME280
The node is based on Arduino, in particular a TTGO ESP32 board ("LORA v1" I think) with onboard SX1276 LoRa chip. The sensor is an SDS-011, just like in the luftdaten project. For humidity/temperature, I am using a BME280 (superior to the DHT11/22).
| TTGO | Module | Remark |
| 5V | SDS011 5V | SDS011 power |
| GND | SDS011 GND | SDS011 ground |
| GPIO35 | SDS011 TXD | data |
| GPIO25 | SDS011 RXD | data |
| 3.3V | BME280 3V | power |
| GPIO4 | BME280 SDA | data |
| GPIO15 | BME280 SCL | data |
| GND | BME280 GND | ground |
For reference:
Source code
Payload encoding
Cayenne
- PM1.0: digital input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3 (optional)
- PM10: digital input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
- PM2.5: digital input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
- Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
- Humidity: humidity (type 104), with value in units of 0.5 %
- Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
- radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about 86400x0.01x2 = 1728 seconds per day send time at the best case.
- TheThingsNetwork has a FUP of 30s of data upload per day, actually a huge restriction compared to the send time allowed purely by radio regulations.
- The Luftdaten backend appears to run on a 5 minute interval, or 288 measurements per day.
- The default Luftdaten firmware sends new data every 145s by default
- skip T/RH/P completely (8 bytes left): SF7 is possible, at SF8 we spend 102 ms per transmission
- skip P only (15 bytes left): SF7 is possible, at SF8 we spend 123 ms per transmission
Node design
- INIT: determine presence of the SDS011, print the SDS011 serial number
- IDLE: wait until the start of the cycle, then turn on the fan
- WARMUP: wait 20 seconds while the sensor "warms up"
- MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
To compile and upload:
TTN key provisioning
- Each node can be programmed with the *same* software, no source code modification is required
- The node administrator needs to enter the following properties at the TTN console, for each node:
- The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
- The App EUI has a fixed value and is the same for all nodes
- The App Key has a fixed value and is the same for all nodes
- Use 32-bit frame counter, disable frame counter checks
- The node does over-the-air-activation (OTAA) only once and then stores the OTAA parameters in internal (simulated) EEPROM. Upon reboot, the node resumes the connection with these parameters
- A long press on the PRG button restarts the OTAA procedure
Backend
- subscribe to a TTN MQTT stream and receive incoming message
- decode Cayenne and custom payloads
- forward to luftdaten.info/sensor.community
- forward to opensensemap.org
- forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Example upstream data:
Example downstream data:
Gateway API:
