Audiocrasher
Revision as of 16:10, 18 February 2019 by Glu (talk | contribs) (NAND audio crasher)
NAND audio crasher
by benadski, made for hackerhotel 2019 through hole soldering workshop
Turns your awkward "Kinderen voor kinderen" collection into nice noise.
Description of this soldering kit:
-Small PCB with 4 jack 3.5mm connectors and potentiometer.
-Turns audio into a squarewave and mixes this with another squarewave.
-Has a gate and CV input.
-Only consumes about 2mA at 5V.
-Accepts line-ish level or piëzo contact microphone signal on the input.
-External control for added functionality. (Connect pin 5 to 6 to shut up CV/Pot controlled modulator for example.)
-"Standard" analog synth power interface
If you design a frontplate it might be a nice addition to your (eurorack) analog synth.
Schematic:
Soldered:
ERRATA: PCB layout error, but it's fixed easily. Solder bridge solution:
The pot provided is 100k, but that does not really matter. :)
