NoiseMeter
Project NoiseMeter
Measuring audio noise as citizen science
Status Initializing
Last Update 2024-04-23
This project is about measuring environmental audio noise as citizen science.
For example, noise can be:
  • road traffic noise (cars, mopeds, etc)
  • air traffic noise,
  • industrial noise, like building activities
Existing sound/noise meter projects:
This project page considers a kind of clone of the Amsterdam Sounds project.
Other interesting stuff:
Nano33 IOT
Nano33 IOT pinout
Hardware is a nano33 iot board.
Connections
SPH0645 nano33 iot Remark
SEL - leave unconnected
LRCK A2 (16) - I2S FS sample clock
DOUT D4 (4) - I2S SD data
BCLK A3 (17) - I2S SCK bit clock
GND GND
3V 3v3
The software is based on Arduino, a kind of clone of the Amsterdam Sounds project, modified to use WiFi (instead of LoRa), written by Rene Kuijf.
My modifications consist of a platformio configuration, for easy building.
See AdamSoundsInflux-slim-nano-33 github repo for the source code.
Casing
Microphone protection
To protect the microphone, use a membrane, like:
Junction box
Simple junction boxes sold by Gamma:
A downward pointing hole can be used for an 868 MHz LoRaWAN antenna.
Sensor.community casing
See https://sensor.community/docs/dnms/dnms-noise-measuring-dn40-result.jpg
Dimensions:
  • microphone is on a half inch (12.7 mm OD) white polystyrene pipe, 115 mm long
  • main piece is 25mm, length 160mm
  • some other connecting piecess
"RIVM" test casing
Exact dimensions unknown, see photo on this page: https://samenmeten.nl/nieuws/citizen-science-geluidmetertest-op-rivm-terrein
My guess:
  • microphone is on a 10mm diameter pipe, length 100mm
  • main case is a 40mm diameter pipe, length 200mm
Experiments
Uni-T UT353 BT noise meter
This thing has bluetooth.
serial interface
There is an internal serial interface (9600 bps). When in bluetooth mode, but not connected yet, there is data going over this interface:
00000000  01 fc 12 aa bb 10 05 3b  20 20 34 31 2e 35 64 42  |.......;  41.5dB|
00000010  41 3d 34 00 04 15 01 fc  12 aa bb 10 05 3b 20 20  |A=4..........;  |
00000020  34 30 2e 33 64 42 41 3d  34 00 04 12 01 fc 12 aa  |40.3dBA=4.......|
00000030  bb 10 05 3b 20 20 33 39  2e 33 64 42 41 3d 34 00  |...;  39.3dBA=4.|
00000040  04 1a 01 fc 12 aa bb 10  05 3b 20 20 33 39 2e 30  |.........;  39.0|
00000050  64 42 41 3d 34 00 04 17  01 fc 12 aa bb 10 05 3b  |dBA=4..........;|
00000060  20 20 33 39 2e 30 64 42  41 3d 34 00 04 17 01 fc  |  39.0dBA=4.....|
00000070  12 aa bb 10 05 3b 20 20  33 38 2e 37 64 42 41 3d  |.....;  38.7dBA=|
00000080  34 00 04 1d 01 fc 12 aa  bb 10 05 3b 20 20 33 38  |4..........;  38|
00000090  2e 37 64 42 41 3d 34 00  04 1d 01 fc 12 aa bb 10  |.7dBA=4.........|
000000a0  05 3b 20 20 33 38 2e 33  64 42 41 3d 34 00 04 19  |.;  38.3dBA=4...|
000000b0  01 fc 12 aa bb 10 05 3b  20 20 33 38 2e 31 64 42  |.......;  38.1dB|
000000c0  41 3d 34 00 04 17 01 fc  12 aa bb 10 05 3b 20 20  |A=4..........;  |
000000d0  33 37 2e 38 64 42 41 3d  34 00 04 1d 01 fc 12 aa  |37.8dBA=4.......|
000000e0  bb 10 05 3b 20 20 33 38  2e 38 64 42 41 3d 34 00  |...;  38.8dBA=4.|
000000f0  04 1e 01 fc 12 aa bb 10  05 3b 20 20 33 38 2e 31  |.........;  38.1|
Dividing into "frames", starting with 01 fc 12 aa bb:
01 fc 12 aa bb 10 05 3b  20 20 34 31 2e 35 64 42 41 3d 34 00 04 15 "41.5dBA"
01 fc 12 aa bb 10 05 3b  20 20 34 30 2e 33 64 42 41 3d 34 00 04 12 "40.3dBA"
01 fc 12 aa bb 10 05 3b  20 20 33 38 2e 38 64 42 41 3d 34 00 04 1e "38.8dBA"
header
                        <----------ASCII--------->
                                                   3d 34 00 04 1e
Each frame is 22 bytes long (0x16)
Bytes:
00: ??
01: ??
02: 'h' when hold is pressed
03: AA always?
04: BB always?
05: 10
06: 01, 05, ??
07: ??
08: 20 ascii
09: 20 ascii
0A: xx ascii
0B: xx ascii
0C: xx ascii
0D: xx ascii
0E: xx ascii
0F: '='
10: '3' when in slow mode, '4' when is fast mode
11: ??
12: ??
13: ??
14: ??
15: ??
BLE interface
This thing has a bluetooth interface. FCC report on the bluetooth part: https://fcc.report/FCC-ID/2AWEE-8762-01/4740558
In short, as I interpret the BLE configuration:
  • a "Generic Attribute Profile" service, like all BLE devices have
  • a service related to bluetooth parameters, also looks fairly standard, and not related to the measurements themselves
  • a "Device information" service
  • a custom vendor-specific service, where I suspect the noise-meter specific data is
In raw format:
  • service 00001801-0000-1000-8000-00805f9b34fb: Generic Attribute Profile
  • service: 0000ff12-0000-1000-8000-00805f9b34fb: Unknown
    • characteristic: 0000ff01-0000-1000-8000-00805f9b34fb Unknown
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Data In"
    • characteristic: 0000ff02-0000-1000-8000-00805f9b34fb Unknown
      • descriptor: 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Data Out"
    • characteristic: 0000ff03-0000-1000-8000-00805f9b34fb Unknown
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Baud Rate"
    • characteristic: 0000ff04-0000-1000-8000-00805f9b34fb Unknown
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Link Interval"
    • characteristic: 0000ff05-0000-1000-8000-00805f9b34fb Unknown
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Pair code"
    • characteristic: 0000ff06-0000-1000-8000-00805f9b34fb
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb "BT Name"
    • characteristic: 0000ff07-0000-1000-8000-00805f9b34fb
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb "Pair Code En"
    • characteristic: 0000ff08-0000-1000-8000-00805f9b34fb
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb "Adv interval"
    • characteristic: 0000ff09-0000-1000-8000-00805f9b34fb
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb "TX Power"
    • characteristic: 0000ff0a-0000-1000-8000-00805f9b34fb
      • ... "MCU Delay"
    • characteristic: 0000ff0b-0000-1000-8000-00805f9b34fb
      • ... "Mode Control"
    • characteristic: 0000fff0-0000-1000-8000-00805f9b34fb
      • ... "Factory Set"
    • characteristic: 0000fff1-0000-1000-8000-00805f9b34fb
      • descriptor: 00002901-0000-1000-8000-00805f9b34fb "Reset"
  • service: 0000180a-0000-1000-8000-00805f9b34fb Device Information
  • service: 0000d0ff-3c17-d293-8e48-14fe2e4da212 Vendor specific
    • characteristic: 0000ffd1-0000-1000-8000-00805f9b34fb Write
    • characteristic: 0000ffd2-0000-1000-8000-00805f9b34fb Read, typically 40C1F6049BD7
    • characteristic: 0000ffd3-0000-1000-8000-00805f9b34fb Read, typically 01901468
    • characteristic: 0000ffd4-0000-1000-8000-00805f9b34fb Read, typically 21100048
    • characteristic: 0000ffd5-0000-1000-8000-00805f9b34fb Read, typically ...?
    • characteristic: 0000ffd8-0000-1000-8000-00805f9b34fb Write
    • characteristic: 0000fff1-0000-1000-8000-00805f9b34fb Read, typically 0501000700080000F00F0000
    • characteristic: 0000fff2-0000-1000-8000-00805f9b34fb Write
    • characteristic: 0000ffe0-0000-1000-8000-00805f9b34fb Read, typically 00 00 00 01 01 00 00 00 01 90 14 68 21 10 00 48
