RevKlanet
Revision as of 03:19, 26 March 2018 by Juerd (talk | contribs)
Project Revklanet
Contact Gori, PeterC
Last Update 2018-03-26
The project to make DIY Alklanet aka RevKlanet, AlklaNEP, Lolklanet or Alklanetniet. Why ? Alklanet is awesome cleaning agent, but is kinda expensive. Can we make something ourselves? Alklanet is a commercial product, with a secret composition. Howewer de MSDS reveals the most common chemicals.
Alklanet facts
  • blue
  • pH 5.5 - 7 according to MSDS, Litmus measures 6
  • 5 -10% 2-Butoxyethanol
  • ? % surfactant
  • ? % ethanol
  • Production of test batches : Making revklanet.jpg
Recipe V0.1
Al %weight, For 200 ml. These will give only apporximate concentrations.
  • 20 g Eco-Aceton from "De Parel" from hornbach
  • 10 g hard soap
  • 10 g ethanol ( Available from drugstores as 95% ethanol for cleaning)
  • 160 g water
Feedback
  • Trouble dissolving all the soap, also feels very soapy, probably way too much.
  • pH 8
  • thrashed
Recipe V0.2
Feedback
  • smells very nice
  • cleans well, but less than Alklanet or 0.3
  • leaves a bit more streaks than Alklanet
Recipe V0.3
Composition
For 200 ml solution, all wt%. These will give only approximate concentrations, as non of the ingredients are pure.
  • 20 g ( 10% ) Eco-Aceton from "De Parel" from hornbach
  • 5 g ( 2.5% ) mirasol 2000 - tenside / wetting agent. MSDS
  • 10 g ( 5%) ethanol ( Available from drugstores as 95% ethanol for cleaning)
  • 172 g ( 82% ) demineralised water
Economics
Product Price per unit (€) Unit (g) Price (€/g) Amount in recipe (g/l) Costs (€/l) link
Eco-Acetone 6.80 1000 0.0068 100 0.680 https://www.pearlpaint.nl/nl/merken-producten/eco-line/aceton-eco_586/
Mirasol 11.95 250 0.0478 25 1.195 https://www.macodirect.de/en/chemistry/machine-chemistry/4690/tetenal-mirasol-2000-antistatic-wetting-agent-250ml MSDS
Ethanol 2.29 100 0.0229 50 1.145 https://www.boodschappenbestellen.com/bestel/etos-alcohol-96/
Demiwater 2.65 5000 0.00053 825 0.437 https://www.makro.nl/cat/nl/products/product/1522040001001
TOTAL - - - 1000 3.46
Feedback
  • pH 6-7
  • Gori: Cleaned the outside glass of the door in the workshop. Seems to remove mystery spots better than Alklanet
  • Gori: when used on a tables, no perceivable difference.
  • joepie91: v0.3 lijkt prima te werken, net tafel mee schoongemaakt, beetje vreemd geurtje maar verder prima
  • Cleans very well, but leaves slightly more streaks than 0.2
Recipe V0.4
For this version, we want to improve both the economics and performance.
  • Replace ethanol with Isopropyl alcohol : Better degreasing properies, and much cheaper
  • Find an alternative surfactant / tenside, in bulk 1/10th of the price may be possible
Composition
For 200 ml solution, all wt%. These will give only approximate concentrations, as none of the ingredients are pure.
  • 5 g ( 2.5% )  ??? surfactant / tenside
  • 10 g ( 5%) IPA ( Available from Revspace, 4 EUR / l)
  • 165 g ( 82% ) demineralised water
Testing
  • Test setup : RevKlanetTestSetup.jpg
    • Compare : Demineralised water, Alklanet, RevKlanet V0.2, RevKlanet V0.3
  • Testing protocol : TestingMaterials.jpg
  • Apply and dry for 30 minites
    • Wok oil
    • Ketjap Manis
    • Ketchup
    • Meggele garlic butter
  • Attempt cleaning with a clean microfibre cloth and report results
    • Spray area with a single pump (we are using old Alklanet bottles)
    • Wipe 1/3 immediately in a single downward stroke
    • Wait 10 seconds then wipe 2nd 1/3 with a single stroke
    • Then clean the final 1/3 until clean
    • Then clean the entire area with the same product
Results V0.2 and v0.3
  • Overall findings : Both V0.2 and V0.3 work as good as Alklanet. V0.3 dries fastest, and degrease markedly better than Alklanet. Probably because we use the a higher concentration of alcohols, and the wetting agent greatly helps as wel.
  • Demiwater : Demiwater.jpg
  • Alklanet : Alklanet.jpg
  • V0.2 : V0.2.jpg
  • V0.3 : V0.3.jpg
