LED skirt
Revision as of 21:27, 21 December 2019 by Noor (talk | contribs)
Project LED-skirt
Contact Noor
Last Update 2019-12-21
To do
  • Fix rest of LED strip(s) onto crinoline.
  • Microcontrollers and wiring.
  • Figure out how much power is needed and battery holders.
  • Apply waterproofing lacquer on circles and panel.
  • Want side-emitting LEDs along the bottom.
  • Diameter of crinoline bottom hoop is 80 cm. Need to add an extra 100+cm of arc length of black paneling and tulle paneling to inner layers.
LED count
  • 240 - circles (all used except one)
  • 64 - 8x8 panel.
  • 23 - strip 1.
  • 23 - strip 2.
Total: 350 LEDs.
Not mounted:
  • 17 - strip 3.
  • 1 - single LED center from circle pack.
Timeline
2019-11-06 - 2019-11-11
Bought:
Old sketches:
2019-11-04 224115 - design1.png 2019-11-04 224123 - led skirt 2.png 2019-11-04 224131 - led skirt 3.png 2019-11-05 215433 - DSC06381.jpg 2019-11-05 215437 - DSC06382.jpg
2019-11-12 - 2019-11-24
  • Layout of LEDs, waiting for items to arrive.
  • Tested out LEDs under layers and on crinoline.
2019-11-23 220454 - DSC06537.jpg 2019-11-23 221724 - DSC06542.jpg 2019-11-24 173747 - DSC06546.jpg
2019-11-25
  • Took apart seams of inner layers of black skirt to add extra panels to fit over crinoline.
2019-11-26
  • Measured skirt on top of crinoline. Extra panel with bottom arc length of 100+cm.
  • Decided to go with 6 strips of 23 LEDs each. Cut one strip.
2019-12-03 - 2019-12-05
  • Tested out LED rings. One wire was detached so had to be soldered on.
2019-12-06
  • Punched holes in crinoline, used zip ties to attach first LED strip.
  • Took apart LED circles and tested FastLED programs.
  • Set up LED circles, one strip, and panel together on crinoline and used zip ties to place everything but the panel on crinoline.
  • Ran FastLED programs on everything together.
  • Pictures posted by others to Facebook, RevSpace kiekjes, Twitter.
2019-12-06 193923 - DSC06635.jpg 2019-12-06 194452 - DSC06637.jpg 2019-12-06 200017 - DSC06639.jpg 2019-12-06 220618 - DSC06666.jpg 2019-12-06 220632 - DSC06667.jpg 2019-12-06 220710 - DSC06668.jpg
2019-12-20
  • Rearranged LED circles, mounted some back on with velcro. Mounted panel with velcro.
  • Cut two more strips. Attached wires to one and mounted it horizontally at an angle.
