File:Plant check fixed.jpg
Original file(600 × 800 pixels, file size: 180 KB, MIME type: image/jpeg)
The setup for now, the box is fixed to the pillar with some double-sided tape. If you pull the box lightly it will come off the pillar. The back of the box is not glued, so you can check out the inner parts. I might add a transmitter one day that spams the IRC channel when the plants are dying.
current06:15, 19 September 2013Thumbnail for version as of 06:15, 19 September 2013600 × 800 (180 KB)Glu (talk | contribs)The setup for now, the box is fixed to the pillar with some double-sided tape. If you pull the box lightly it will come off the pillar. The back of the box is not glued, so you can check out the inner parts. I might add a transmitter one day that spams th
