IgorsProjectIdeas
Revision as of 10:51, 6 November 2011 by Maxell (talk | contribs)
Igors Projects
Current project
Basic reading  : http://www.allaboutcircuits.com/
  • Helping out with the physical component part. Stripping, recycing connectors etc.
Button Driven Evolution
See the ButtonDrivenEvolution page. Control a Agent Based Model of genetic evolution throug a button box
Completed projects
Chaotic Circuits
See the ChaoticCircuits page. Works very nice as a demo, will not be upgraded to a full class demo, as it requires too much background knowledge.
Drawdio
Idea storage
These are ideas that have not graduated to a official project. Once they are, an appropriate project page will be created from them. Feel free to steal/adopt/contribute ideas !
Random number generators
USB readable circuitry that streams random numbers. The quality can be tested using : http://en.wikipedia.org/wiki/Diehard_tests. While these things do not have not real practical use, they are useful for paranoid crypto, and for getting super good LHS samples testing ABM. However, getting a circuit that is better than a modern Mersenne-twister algorithm is VERY hard.
FollowMeTernet
an physical internet terminal, on legs/wheels that follows you arround, On command, it can find its hocking station, and return from it to find you.
Estimated components
  • remote controlled car / roomba
  • netbook
  • arduino, to collect sensor input data
  • bunch of sensors to tell it where it is / get a kinect, and let it drive where there is space.
Tensegrity toys
Beam toys
  • Learn about BEAM robotics by building toys for the boys
  • Either implement the designs from the BEAM book, or adapt some of the toy cars
Brewing mead
Soldering ventilation
Vent system for remove soldering fumes from the work bench
  • old fans from computer cases
  • flexible auminium duct from above the table to the window / main ventilation tube
  • two/three adjustable lamp arm mounted tubes from ceiling to the desk surface
Revelation From Above
Areal kite photography/filming
http://www.kaper.us/basics/BASICS_picavet.htmlOptions:
  • A camera is needed. : nikon d50 with a wide angle lens is available, but expensive/risky to use
  • A remote trigger is needed
  • Kite :
  • Steerable kite
    • pros:
    • cons
      • this does not go very high
      • is quite dynamic
  • Single line kite : For a nice shot from great altitude a single line kite is preferable
    • pros
      • Very stable
      • very long line possible
    • cons
      • needs to be built/purchased
      • unclear what the lifting force is
Quadcopter
  • see http://aeroquad.com/ - Open Source quadcopter, based on Arduino - (note: turiphro has a quadcopter)
  • Relatively expensive: + 200 EUR for parts
  • Quite complex electronics
  • Use :
    • Fun
    • Platform for Revelation From Above
    • RevSpace security drone, launch on alarm from the roof, film the area for evidence :)
  • Period 1 of the circuit:
    <img src="/old/1-period.JPG" alt="1-period.JPG" width='3008' height='2000' />
