Spoorlaan-b1
! version 12.1 no service pad service timestamps debug uptime service timestamps log datetime msec localtime show-timezone service password-encryption ! hostname spoorlaan-b1 ! enable password 7 XXXXXXXXXXXXXXXXXXX ! clock timezone GMT+1 1 clock summer-time GMT+1 recurring ip subnet-zero ! ip name-server 10.0.5.1 ip ssh time-out 120 ip ssh authentication-retries 3 ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id spanning-tree vlan 1-4094 priority 4096 ! ! ! ! interface Port-channel1 ! interface FastEthernet0/1
description "Revspace management" switchport access vlan 10 switchport mode access logging event spanning-tree logging event status shutdown
! interface FastEthernet0/2
description "Gateway (Spoorlaan B)" switchport trunk allowed vlan 5,11-99 switchport mode trunk logging event spanning-tree logging event status speed 100 spanning-tree portfast
! interface FastEthernet0/3
description "VLAN 11 10.0.11.0/24" switchport access vlan 11 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/4
description "VLAN 12 10.0.12.0/24" switchport access vlan 12 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/5
description "VLAN 13 10.0.13.0/24" switchport access vlan 13 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/6
description "VLAN 14 10.0.14.0/24" switchport access vlan 14 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/7
description "VLAN 15 10.0.15.0/24" switchport access vlan 15 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/8
description "VLAN 16 10.0.16.0/24" switchport access vlan 16 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/9
description "VLAN 17 10.0.17.0/24" switchport access vlan 17 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/10
description "VLAN 18 10.0.18.0/24" switchport access vlan 18 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/11
description "VLAN 19 10.0.19.0/24" switchport access vlan 19 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/12
description "VLAN 20 10.0.20.0/24" switchport access vlan 20 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/13
description "VLAN 21 10.0.21.0/24" switchport access vlan 21 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/14
description "VLAN 22 10.0.22.0/24" switchport access vlan 22 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/15
description "VLAN 23 10.0.23.0/24" switchport access vlan 23 switchport mode access logging event spanning-tree logging event status
! interface FastEthernet0/16
! interface FastEthernet0/17
! interface FastEthernet0/18
! interface FastEthernet0/19
! interface FastEthernet0/20
! interface FastEthernet0/21
! interface FastEthernet0/22
! interface FastEthernet0/23
! interface FastEthernet0/24
! interface FastEthernet0/25
! interface FastEthernet0/26
! interface FastEthernet0/27
! interface FastEthernet0/28
! interface FastEthernet0/29
! interface FastEthernet0/30
! interface FastEthernet0/31
! interface FastEthernet0/32
! interface FastEthernet0/33
! interface FastEthernet0/34
! interface FastEthernet0/35
! interface FastEthernet0/36
! interface FastEthernet0/37
! interface FastEthernet0/38
! interface FastEthernet0/39
! interface FastEthernet0/40
! interface FastEthernet0/41
! interface FastEthernet0/42
! interface FastEthernet0/43
! interface FastEthernet0/44
! interface FastEthernet0/45
! interface FastEthernet0/46
description "Fileserver, vlan 42 (revspace)" switchport access vlan 42 switchport mode access logging event spanning-tree logging event status speed 100 duplex full
! interface FastEthernet0/47
description "Uplink naar spoorlaan-d1 Fa0/47" switchport trunk allowed vlan 1-100,999 switchport mode trunk logging event spanning-tree logging event status speed 100 duplex full
! interface FastEthernet0/48
! interface GigabitEthernet0/1 ! interface GigabitEthernet0/2 ! interface Vlan1
no ip address no ip route-cache shutdown
! interface Vlan5
ip address 10.0.5.11 255.255.255.0 no ip route-cache
! ip default-gateway 10.0.5.1 ip http server logging trap debugging logging 10.0.5.1 snmp-server community rev10 RO banner motd ^CC
- NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE*******
(_) (_)
/_____\ _____ _____ /_____\
|.;.| | __ \ / ____| |.;.|
\(%)/ | |__) |_____ _| (___ _ __ __ _ ___ ___ \(%)/
\_/ | _ // _ \ \ / /\___ \| '_ \ / _` |/ __/ _ \ \_/
o=={_}==o | | \ \ __/\ V / ____) | |_) | (_| | (_| __/ o=={_}==o
| | |_| \_\___| \_/ |_____/| .__/ \__,_|\___\___| | |
| | |_| | |
| | This system is for the use of authorized HACKERS only! | |
| | So that is probly NOT you. Use of this system without | |
| | prior consent will probably result in an intimate date | |
| | with a lart. Please be adviced that in doubt you are | |
| | probably not skilled enough to proceed and you should | |
| | walk away immediately! | |
___|_|___ ___|_|___
^C ! line con 0
password 7 XXXXXXXXXXXXXXXXXX stopbits 1
line vty 0 4
password 7 XXXXXXXXXXXXXXXXXX login
line vty 5 15
login
! ntp clock-period 17179925 ntp server 91.198.87.118 ! end
