Spoorlaan-b1
Config Summary
- p1: Empty
- p2: "Router" (Algemene gateway) (Router gebouw B) VLAN 5,11-99
- p3: Huurder VLAN 11
- p4: Huurder VLAN 12
- p5: Huurder VLAN 13
- p6: Huurder VLAN 14
- p7: Huurder VLAN 15
- p8: Huurder VLAN 16
- p9: Huurder VLAN 17
- p10: Huurder VLAN 18
- p11: Huurder VLAN 19 (Link naar sparkshack2 (tijdelijk))
- p12: Huurder VLAN 20
- p13: Huurder VLAN 21
- p14: Huurder VLAN 22
- p15: Huurder VLAN 23
- p16-45: Down/Unused
- p46: Vlan 42, unused (revspace)
- p47: Trunk/Uplink naar gebouw D / 'gateway'
- p48: Unused
- g1/g2: Fiber poorten, unused
Config
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname spoorlaan-b1
enable password 7 XXXXXXXXXXXXXXXXXXX
clock timezone GMT+1 1
clock summer-time GMT+1 recurring
ip subnet-zero
ip name-server 10.0.5.1
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree extend system-id
spanning-tree vlan 1-4094 priority 4096
interface Port-channel1
interface FastEthernet0/1
description "Revspace management"
switchport access vlan 10
switchport mode access
logging event spanning-tree
logging event status
shutdown
interface FastEthernet0/2
description "Gateway (Spoorlaan B)"
switchport trunk allowed vlan 5,11-99
switchport mode trunk
speed 100
spanning-tree portfast
interface FastEthernet0/3
description "VLAN 11 10.0.11.0/24"
switchport access vlan 11
interface FastEthernet0/4
description "VLAN 12 10.0.12.0/24"
switchport access vlan 12
interface FastEthernet0/5
description "VLAN 13 10.0.13.0/24"
switchport access vlan 13
interface FastEthernet0/6
description "VLAN 14 10.0.14.0/24"
switchport access vlan 14
interface FastEthernet0/7
description "VLAN 15 10.0.15.0/24"
switchport access vlan 15
interface FastEthernet0/8
description "VLAN 16 10.0.16.0/24"
switchport access vlan 16
interface FastEthernet0/9
description "VLAN 17 10.0.17.0/24"
switchport access vlan 17
interface FastEthernet0/10
description "VLAN 18 10.0.18.0/24"
switchport access vlan 18
interface FastEthernet0/11
description "VLAN 19 10.0.19.0/24"
switchport access vlan 19
interface FastEthernet0/12
description "VLAN 20 10.0.20.0/24"
switchport access vlan 20
interface FastEthernet0/13
description "VLAN 21 10.0.21.0/24"
switchport access vlan 21
interface FastEthernet0/14
description "VLAN 22 10.0.22.0/24"
switchport access vlan 22
interface FastEthernet0/15
description "VLAN 23 10.0.23.0/24"
switchport access vlan 23
interface FastEthernet0/16
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
shutdown
interface FastEthernet0/21
shutdown
interface FastEthernet0/22
shutdown
interface FastEthernet0/23
shutdown
interface FastEthernet0/24
shutdown
interface FastEthernet0/25
shutdown
interface FastEthernet0/26
shutdown
interface FastEthernet0/27
shutdown
interface FastEthernet0/28
shutdown
interface FastEthernet0/29
shutdown
interface FastEthernet0/30
shutdown
interface FastEthernet0/31
shutdown
interface FastEthernet0/32
shutdown
interface FastEthernet0/33
shutdown
interface FastEthernet0/34
shutdown
interface FastEthernet0/35
shutdown
interface FastEthernet0/36
shutdown
interface FastEthernet0/37
shutdown
interface FastEthernet0/38
shutdown
interface FastEthernet0/39
shutdown
interface FastEthernet0/40
shutdown
interface FastEthernet0/41
shutdown
interface FastEthernet0/42
shutdown
interface FastEthernet0/43
shutdown
interface FastEthernet0/44
shutdown
interface FastEthernet0/45
shutdown
interface FastEthernet0/46
description "Fileserver, vlan 42 (revspace)"
switchport access vlan 42
speed 100
duplex full
interface FastEthernet0/47
description "Uplink naar spoorlaan-d1 Fa0/47"
switchport trunk allowed vlan 1-100,999
speed 100
duplex full
interface FastEthernet0/48
speed 100
duplex full
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan5
ip address 10.0.5.11 255.255.255.0
no ip route-cache
ip default-gateway 10.0.5.1
ip http server
logging trap debugging
logging 10.0.5.1
snmp-server community rev10 RO
banner motd ^CC
******NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE*******
(_) (_)
/_____\ _____ _____ /_____\
|.;.| | __ \ / ____| |.;.|
\(%)/ | |__) |_____ _| (___ _ __ __ _ ___ ___ \(%)/
\_/ | _ // _ \ \ / /\___ \| '_ \ / _` |/ __/ _ \ \_/
o=={_}==o | | \ \ __/\ V / ____) | |_) | (_| | (_| __/ o=={_}==o
| | |_| \_\___| \_/ |_____/| .__/ \__,_|\___\___| | |
| | |_| | |
| | This system is for the use of authorized HACKERS only! | |
| | So that is probly NOT you. Use of this system without | |
| | prior consent will probably result in an intimate date | |
| | with a lart. Please be adviced that in doubt you are | |
| | probably not skilled enough to proceed and you should | |
| | walk away immediately! | |
___|_|___ ___|_|___
^C
line con 0
stopbits 1
line vty 0 4
login
line vty 5 15
login
ntp clock-period 17179925
ntp server 91.198.87.118
end
