DebiSampler
Versie door 10.42.42.9 (overleg) op 1 okt 2011 om 23:20 (Created page with " DebiSampler is a project to create a Stage Synthesiser based on off the shelf hardware with some customising and creativity, Debian and the Linuxsampler software. | To Do | Des...")
(wijz) ← Oudere versie | Huidige versie (wijz) | Nieuwere versie → (wijz)
DebiSampler is a project to create a Stage Synthesiser based on off the shelf hardware with some customising and creativity, Debian and the Linuxsampler software. | To Do | Description | Status | | Basic Board Installation | Install and Config: Debian, Xorg, OpenJDK, Debisampler, Alsa, Jack | Done | | Install Realtime Kernel | Provide debian with a Realtime Kernel (http://www.ptxdist.org/software/linux-rt/debian_en.html) | Done | | NVIDIA + RT Kernel | Customise and Compile the NVIDIA driver against the Realtime Kernel | Done | | Order and Install SSD | Change the CF card with cheap Transcend SSD (Thanks foobs!) | In Progress | | Startup script | Create startup script using SH, init jack with commands, start linuxsampler, start Xorg with Fantasia java interface | Done | | LSCP Script | Create a LSCP startup script to automate Linuxsampler (init jack, connect midi, create track etc) | In Progress | | Sample Cards | Order and Install multicard-reader with auto mounting to /samples with 775 permissions | Planning | | Plexiglas Heater | Create a Plexiglas heater and bender for the Casing (example: http://farm1.static.flickr.com/39/87088389_54772d8cf9.jpg) | Planning | | Bend Casing | Bend the casing for the synth | Planning | | Install Touchscreen | Order and install the 7" touchscreen | Planning | | Customise GUI | Borrow a coder to customise the Jsampler/Fantasia GUI | Planning | | Plugs | Order and Install XLR and Jack outputs, external MIDI etc | Planning | | Install the rest! | Place and install all the additional hardware | Planning | | Paintjob | Make everything sparkly | Planning |
