ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone | |
My clone of the Sinclair ZX81 | |
Contact | Mahjongg |
Last Update | 2020-07-10 |
My ZX81+35, ZX-81 clone, previously called the ZX14m ZX15, and ZX81+34 (2015 Version) retro homecomputer is a much improved Sinclair ZX81 [1] clone built with the modern materials techniques and components of 2015. The ZX81+35 will be first built and tested in 2016.
Afterwards I got many comments that for a kit it was too difficult to build due to the use of SMT. So I also started on a much simpler to build ZX81+38, which can be mounted in an original ZX81 case, and is more a real clone, just with re-created ULA logic with discrete (PTH) logic chips. This is now (june 2020) finished. and berbers are uploaded to GitHub.
The ZX81+38 is now the preferred version, and is designed to be used as a drop-in replacement of the PCB of a real ZX81, with conventional DIP IC's replacing the ULA.
more info about it here: [2]
Note that due to the corona crisis (and the fact that I'm currently unemployed, so low of disposable cash) I have not yet build and tested the later ZX81+38 version, but as its based on the same schematic, I'm 99.9% sure it will work file.
As for now comments and questions on the design can be made here [4] (raspberry PI forum off topic section) :-)
Introduction to the ZX81+35
- Design files are freely available on GitHub from july 31 2019 (but do note that firmware is still © Amstrad!)
- wilf rigter's "THE ZX97LITE SCHEMATIC DISASSEMBLED Rev.pdf"
- wilf rigters "turbo.pdf"
- wilf rigters "ZX81WAIt.pdf"
- Kevin bakers, "turbo switch circuit.gif" redrawn by wilf rigter
- Rodney knaaps ZX81 rebuilds # 1, #2 and #3
- "ZX81 ULA Replacement By Andrew Rea.pdf"
- "zx96mainboard schematic.gif"
- Alwin Henseler's "ZX81_ULA-in-a-CPLD_v1.10.zip"
- grant searle's "ZX80nmiVer4.1.jpg" slow mode extension for ZX80
- PokeMon's "ZX80CORE-manual-EN.pdf"
- Andy Rea "mini ZX81" page 1 to 4
- Other ZX80 /ZX81 info:
- "ZX81 Service and Assembly Manual (scans) kopie.pdf"
- "The Complete zx81 Rom Disassembly.pdf"
- "Assembly Listing of the Operating System of the Sinclair ZX80..html"
- "zx80_schema redrawn A3.pdf"
- "Sinclair ZX80/81 etc Specifications.pdf"
- "graphic view of zx81 rom.jpg"
- "ZX81 schematic highres.jpg"
- "Microace_Diagram_s1.jpg"
- "annotated redrawn zx80-schema.gif" by NoCash
- "brazilian slow mode adapter schematic .jpg" part 1 and 2
- "ZX81CCP_schematic.jpg"
- "jupiter ace 4000.pdf" by Bodo Wenzel
- "cp-200 (ZX81 clone) schemas"
- "tk82 (ZX81 clone) schemas"
- "power 3000 (lambda 8300) schematic.gif"
- "ts1500 schematic (scan).gif"
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81plus34 rev2.00 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81plus34 kleur rev 1.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81plus34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
Here is the schematic (plus board layout) of the keyboard: File:KB matrix schematic.pdf Note this schematic is the corrected version that is compatible with a real ZX81, so it uses the address order A11, A10, A12, A9, A13, A8, A14, A15 It doesn't include connections for LED's or the reset input.
A version that supports the ZXPand can be downloaded here: File:New ZX81plus34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81plus35 REV 2.2.pdf a coloured version is here: File:ZX81plus35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
The .ODF spreadsheet can be downloaded here: File:ZX81plus35(ZX14) - Bill Of Materials corrected.ods
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
its a great milestone! And I'm glad I got it working, before the launch of the Raspberry PI 3 :-) . Not that I'm satisfied, its still far from a state in which I would be completely satisfied with it. To start with the keyboard is not wired up correctly, (see entry 2 February 2016 for that) and on top of that not all keys are working, in fact it was a struggle to produce the "hello world" text ("hallo world" actually) you see in the picture below. Also I was not satisfied with the black letters on a white background, the letters were very "thin" and hard to read, so I jumpered the board up to produce white text on a black background, as you can see in the picture below (sorry the picture is a bit fuzzy, cheap camera).
- keyboard connector that is compatible with the original ZX81, and can take its connectors.
- the video/sync combiner was modified to give a clean and compatible composite video signal.
- pin 15 of U9 (shift register 74HC165) connects to GND not CLK, which is more logical and clean.
- Wired the RCA connector correctly with pin 2 on GND and signal on pin 1
- Changed T8 to a faster PMEG2005 transistor for better picture quality
here is the updated .PDF, further updates are likely: File:ZX81plus35 REV 3.0 13 3 16.pdf
This means I will have very limited access to RevSpace :-( The good new is that I now know that I have Sleep Apnea (Apneu in Dutch) which means that I have over 30 breathing stops per hour in my sleep each night, which nearly wake me up. Its the reason for being tired all the time, and for my subconscious fear of going to bed which has lead to a very strange biorhythm. Also good news is that apnea is treatable, with an overpressure (APAP) device I will need to wear in my sleep, I will get a test for one next week (normally it takes over a week, so I'm lucky). Id did a sleepover at MCH and can say the APAP device worked very well for me, I will be offered one in two to three weeks time, I can't wait! If I used it for 2 months and it works well, I will get my permission to drive back.
I tried to design a schematic of the original Zon-81 before creating my own compatible version. A first (unfinished) version of the schematic can be found here: File:Sound expansion (preliminary).pdf
While designing the PSG expansion board I look once again to the expansion port and made a discovery that made me say some expletives &*$$$#)**^& ! I've made a mistake in the very beginning about the orientation of the expansion connector, such that it is now upside-down to how it should have been. This error is expressed in how the expansion connector was drawn in the schematics, (which probably explains the origin of the error) with pin 1 on top, and pin 23 on the bottom, but the edge connector should have been just rotated 90 degrees clockwise, which means pin 1 should have been on the bottom, not on the top, that is, If I wanted to be compatible with a real ZX81, which I do!!
So I started by modifying the schematic, so it corresponds with how it should be laid out. this is the new schematic, I consider the change big enough to warrant updating to revision 4.0: File:ZX81plus35 REV 4.0.pdf
2017 has arrived
it now includes:
- Schematic for revision 4.0 (the latest version) as a .PDF (File:ZX81plus35 REV 4.0.pdf)
- Bill of materials (updated to the latest version) as .ODS (spreadsheet)
- Ulticap and ultiboard files of the schematic and layout (CAD files)
- production files (gerbera and drill files for revision 4.0) you can upload to any PCB manufacturer to get your own PCB (only main PCB, for now, not keyboard PCB, but you can hand build one with perfboard)
- previews of the Top and bottom of the revision 4.0 PCB, so you can see what the PCB should look like.
- keyboard overlay as .PDF (original version) you can plasticise it, and stick it over your keyboard.
to come (I'm working on it):
- Keyboard PCB layout
My prototype keyboard had roughly the same size as the original, although a tiny bit larger, but now I have designed the keyboard PCB so that its outer dimensions are such that it exactly fits inside the recess of a real ZX-81, (after you round off the PCB corners a bit with a file) and its flat wire connection should fit exactly through the slit in the real ZX-81 enclosure. This means the PCB is 2.5 inch high, and 6.2 inch wide, this is a preview of the placement, of the buttons, and connectors, and the PCB size. File:ZX-81 Keyboard-F.SilkS.pdf
The carefully checked keyboard schematic for the ZX81plus35 is here:
File:ZX-81plus35 Keyboard.pdf
and this is a picture of this .PDF:
10 FOR X = 0 TO 255
20 PRINT CHR$ X;
30 NEXT X
These picture shows screenshots of the gerber files I downloaded from GitHub end June, 2020, left the full picture right details showing errors in the soldermasking, so this is the old rev 4,0 version, don't use this to create PCB's!
If you want the latest schematic, here it is: File:ZX81+35 REV 4.1 schematic.pdf
