ZX81PLUS35 ZX81 clone
Revision as of 14:46, 10 July 2020 by Mahjongg (talk | contribs)
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Contact Mahjongg
Last Update 2020-07-10
My ZX81+35, ZX-81 clone, previously called the ZX14m ZX15, and ZX81+34 (2015 Version) retro homecomputer is a much improved Sinclair ZX81 [1] clone built with the modern materials techniques and components of 2015. The ZX81+35 will be first built and tested in 2016.
Afterwards I got many comments that for a kit it was too difficult to build due to the use of SMT. So I also started on a much simpler to build ZX81+38, which can be mounted in an original ZX81 case, and is more a real clone, just with re-created ULA logic with discrete (PTH) logic chips. This is now (june 2020) finished. and berbers are uploaded to GitHub.
The ZX81+38 is now the preferred version, and is designed to be used as a drop-in replacement of the PCB of a real ZX81
more info about it here: [2]
Note that due to the corona crisis (and the fact that I'm currently unemployed, so low of disposable cash) I have not yet build and tested the later ZX81+38 version, but as its based on the same schematic, I'm 99.9% sure it will work file.
Introduction to the ZX81+35
  • wilf rigters "turbo.pdf"
  • wilf rigters "ZX81WAIt.pdf"
  • Other ZX80 /ZX81 info:
  • "Microace_Diagram_s1.jpg"
  • "ZX81CCP_schematic.jpg"
  • "tk82 (ZX81 clone) schemas"
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81plus34 rev2.00 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81plus34 kleur rev 1.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81plus34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
Here is the schematic (plus board layout) of the keyboard: File:KB matrix schematic.pdf Note this schematic is the corrected version that is compatible with a real ZX81, so it uses the address order A11, A10, A12, A9, A13, A8, A14, A15 It doesn't include connections for LED's or the reset input.
File:Nieuw keyboard ZX14.pdf
A version that supports the ZXPand can be downloaded here: File:New ZX81plus34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
File:ZX81PLUS34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81plus35 REV 2.2.pdf a coloured version is here: File:ZX81plus35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
The .ODF spreadsheet can be downloaded here: File:ZX81plus35(ZX14) - Bill Of Materials corrected.ods
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
File:ZX81plus35 REV 2.3.pdf
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
here is the updated .PDF, further updates are likely: File:ZX81plus35 REV 3.0 13 3 16.pdf
I tried to design a schematic of the original Zon-81 before creating my own compatible version. A first (unfinished) version of the schematic can be found here: File:Sound expansion (preliminary).pdf
So I started by modifying the schematic, so it corresponds with how it should be laid out. this is the new schematic, I consider the change big enough to warrant updating to revision 4.0: File:ZX81plus35 REV 4.0.pdf
2017 has arrived
it now includes:
  • Schematic for revision 4.0 (the latest version) as a .PDF (File:ZX81plus35 REV 4.0.pdf)
to come (I'm working on it):
  • Keyboard PCB layout
My prototype keyboard had roughly the same size as the original, although a tiny bit larger, but now I have designed the keyboard PCB so that its outer dimensions are such that it exactly fits inside the recess of a real ZX-81, (after you round off the PCB corners a bit with a file) and its flat wire connection should fit exactly through the slit in the real ZX-81 enclosure. This means the PCB is 2.5 inch high, and 6.2 inch wide, this is a preview of the placement, of the buttons, and connectors, and the PCB size. File:ZX-81 Keyboard-F.SilkS.pdf
The carefully checked keyboard schematic for the ZX81plus35 is here: File:ZX-81plus35 Keyboard.pdf and this is a picture of this .PDF:
10 FOR X = 0 TO 255
20 PRINT CHR$ X;
30 NEXT X
These picture shows screenshots of the gerber files I downloaded from GitHub end June, 2020, left the full picture right details showing errors in the soldermasking, so this is the old rev 4,0 version, don't use this to create PCB's!
If you want the latest schematic, here it is: File:ZX81+35 REV 4.1 schematic.pdf
