Stofradar
Versie door Bertrik Sikken (overleg | bijdragen) op 30 jun 2018 om 17:10 (atmospheric particulate matter)
Project Stofradar
Visualizing atmospheric particulate matter concentrations on a map
Last Update 2018-06-30
This page is about creating a 'stofradar' image of atmospheric particulate matter concentrations based on the raw data measured by the luftdaten.info network, see www.stofradar.nl.
See also my DustSensor page.
luftdaten.info is an initiative to allow citizens to measure atmospheric particulate matter concentration using an inexpensive and easy to build sensor. They collect this data, calculate 5 minute and daily averages and publish it again as open data. The total number of sensors is about 5000 worldwide, most of them in Germany, Bulgaria, Belgium, Austria, Sweden. The Netherlands has about 100 sensors.
Future activities:
  • get an OSM background map, once their export functionality works again
  • fix alignment between map and dust overlay
  • add a timestamp to the image
  • put all of the images from one day into an animation
  • also create a map of a larger area, including germany (it has a lot of data points)
  • massage the data a bit, e.g. remove sensors that are known to give anomalous readings, etc.
Visualisation
Background map
Pages to investigate:
What I need/want is to be able to specify the 'bounding box' and use a equirectangular projection, so I can easily map a pixel back to a latitude/longitude.
Interpolation
To calculate the distance2, I use a very simple approximation:
  • determine the difference in longitude and latitude
  • apply an 'aspect ratio' factor of cos(latitude) to the longitude difference. I use the latitude of the approximate middle of the netherlands (52.2 lat, 5.3 lon) to calculate this aspect ratio factor.
  • distance2 = (difference latitude)2 + (difference longitude)2
A better way would be to use the 'great-circle-distance' and possibly even account for the fact that the earth is not perfectly spherical, but I like to start simple and this makes the calculation a lot faster.
Colour range
The colours I'm using (a kind of inverted spectral range from blue to red):
  • 0 ug/m3: fully transparent white (#FFFFFF)
  • 25 ug/m3: semi-transparent cyan (#00FFFF)
  • 50 ug/m3: semi-transparent yellow (#FFFF00). This is the threshold for the maximum daily average in the Netherlands.
  • 100 ug/m3: semi-transparent red (#FF0000)
  • 200 ug/m3 and higher: semi-transparent purple (#FF00FF)
This scale is approximately logarithmic, with each step being twice as big as the previous one.
Compositing
I use imagemagick for this, for example:
 composite -compose over -geometry 600x800 20180605_210100.json.png netherlands.png output.png
where netherlands.png is an 600x800 opaque black-and-white image of the map of the netherlands and 20180605_210100.json.png is an 60x80 image of dust concentrations with an alpha channel
