ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone | |
My clone of the Sinclair ZX81 | |
Contact | Mahjongg |
Last Update | 2016-11-02 |
As for now comments and questions on the design can be made here [3] (raspberry PI forum off topic section) :-)
Introduction to the ZX81+35
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81plus34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81plus34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81plus34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
A version that supports the ZXPand can be downloaded here: File:New ZX81plus34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81plus35 REV 2.2.pdf a coloured version is here: File:ZX81plus35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
The .JPG can be downloaded here; File:ZX81plus35 rev2.2 - Bill Of Materials.pdf and the .ODF spreadsheet here: File:ZX81plus358 rev2.2 Bill Of Materials.ods
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
its a great milestone! And I'm glad I got it working, before the launch of the Raspberry PI 3 :-) . Not that I'm satisfied, its still far from a state in which I would be completely satisfied with it. To start with the keyboard is not wired up correctly, (see entry 2 February 2016 for that) and on top of that not all keys are working, in fact it was a struggle to produce the "hello world" text ("hallo world" actually) you see in the picture below. Also I was not satisfied with the black letters on a white background, the letters were very "thin" and hard to read, so I jumpered the board up to produce white text on a black background, as you can see in the picture below (sorry the picture is a bit fuzzy, cheap camera).
- keyboard connector that is compatible with the original ZX81, and can take its connectors.
- the video/sync combiner was modified to give a clean and compatible composite video signal.
- pin 15 of U9 (shift register 74HC165) connects to GND not CLK, which is more logical and clean.
- Wired the RCA connector correctly with pin 2 on GND and signal on pin 1
- Changed T8 to a faster PMEG2005 transistor for better picture quality
here is the updated .PDF, further updates are likely: File:ZX81plus35 REV 3.0.pdf
This means I will have every limited access to RevSpace :-( The good new is that I now know that I have Sleep Apnea (Apneu in Dutch) which means that I have over 30 breathing stops in my sleep each night, which nearly wake me up. Its the reason for being tired all the time, and for my subconscious fear of going to bed which has lead to a very strange biorhythm. Also good news is that apnea is treatable, with an overpressure (APAP) device I will need to wear in my sleep, I will get a test for one next week (normally it takes over a week, so I'm lucky). Id did a sleepover at MCH and can say the APAP device worked very well for me, I will be offered one in two to three weeks time, I can't wait! If I used it for 2 months and it works well, I will get my permission to drive back.
I tried to design a schematic of the original Zon-81 before creating my own compatible version. A first (unfinished) version of the schematic can be found here: File:Sound expansion (preliminary).pdf
While designing the PSG expansion board I look once again to the expansion port and made a discovery that made me say some expletives &*$$$#)**^& ! I've made a mistake in the very beginning about the orientation of the expansion connector, such that it is now upside-down to how it should have been. This error is expressed in how the expansion connector was drawn in the schematics, (which probably explains the origin of the error) with pin 1 on top, and pin 23 on the bottom, but the edge connector should have been just rotated 90 degrees clockwise, which means pin 1 should have been on the bottom, not on the top!
So I started by modifying the schematic, so it corresponds with how it should be laid out. this is the new schematic, I consider the change big enough to warrant updating to revision 4.0: File:ZX81plus35 REV 4.0.pdf
As you can see this is a quite large change. Specifically in the top left corner.
This website has developed a problem; redirects with "+" sign in the filename no longer work! I have replaced the latest pictures and .PDF files with ones that use "plus" instead of the + character. The web master is aware of the problem, and he has renamed a few pages, so you can at least visit my two projects that had a + in the filename. Hopefully the problem will be resolved soon, probably by replacing each "+" in an URL to a .PDF by "plus". On November 3 I managed to change the filenames pointing to .PDF's (and a few other non picture formats) in this and the other affected pages to versions with "plus" instead of "+", in the hope that the webmaster will come through with his promise to do the same for these files, so the pointers do point to a valid location once more. doing that to URL's pointing to .PNG pictures might be trickier as changing the URL may delete the picture itself in this thread, until the pictures URL is also changed. So for now I only replaced URL's not used in pictures. until i'm informed the pictures are copied to ones using "plus" instead of "+" in their filename. There is also the case of another page like this, (https://revspace.nl/ZX81%2B34) a predecessor of this page talking about why I wanted to create the ZX81 clone that cannot be accessed right now because it also has a "+" in the file name.
