Spoorlaan-b1
Revision as of 17:42, 22 November 2015 by FooBar (talk | contribs) (Created page with "! version 12.1 no service pad service timestamps debug uptime service timestamps log datetime msec localtime show-timezone service password-encryption ! hostname spoorlaan-b1...")
! version 12.1 no service pad service timestamps debug uptime service timestamps log datetime msec localtime show-timezone service password-encryption ! hostname spoorlaan-b1 ! enable password 7 XXXXXXXXXXXXXXXXXXX ! clock timezone GMT+1 1 clock summer-time GMT+1 recurring ip subnet-zero ! ip name-server 10.0.5.1 ip ssh time-out 120 ip ssh authentication-retries 3 ! ! spanning-tree mode pvst no spanning-tree optimize bpdu transmission spanning-tree extend system-id spanning-tree vlan 1-4094 priority 4096 ! ! ! ! interface Port-channel1 ! interface FastEthernet0/1
description "Revspace management"
switchport access vlan 10
switchport mode access
logging event spanning-tree
logging event status
shutdown
! interface FastEthernet0/2
description "Gateway (Spoorlaan B)"
switchport trunk allowed vlan 5,11-99
switchport mode trunk
speed 100
spanning-tree portfast
! interface FastEthernet0/3
description "VLAN 11 10.0.11.0/24"
switchport access vlan 11
! interface FastEthernet0/4
description "VLAN 12 10.0.12.0/24"
switchport access vlan 12
! interface FastEthernet0/5
description "VLAN 13 10.0.13.0/24"
switchport access vlan 13
! interface FastEthernet0/6
description "VLAN 14 10.0.14.0/24"
switchport access vlan 14
! interface FastEthernet0/7
description "VLAN 15 10.0.15.0/24"
switchport access vlan 15
! interface FastEthernet0/8
description "VLAN 16 10.0.16.0/24"
switchport access vlan 16
! interface FastEthernet0/9
description "VLAN 17 10.0.17.0/24"
switchport access vlan 17
! interface FastEthernet0/10
description "VLAN 18 10.0.18.0/24"
switchport access vlan 18
! interface FastEthernet0/11
description "VLAN 19 10.0.19.0/24"
switchport access vlan 19
! interface FastEthernet0/12
description "VLAN 20 10.0.20.0/24"
switchport access vlan 20
! interface FastEthernet0/13
description "VLAN 21 10.0.21.0/24"
switchport access vlan 21
! interface FastEthernet0/14
description "VLAN 22 10.0.22.0/24"
switchport access vlan 22
! interface FastEthernet0/15
description "VLAN 23 10.0.23.0/24"
switchport access vlan 23
! interface FastEthernet0/16
shutdown
! interface FastEthernet0/17
shutdown
! interface FastEthernet0/18
shutdown
! interface FastEthernet0/19
shutdown
! interface FastEthernet0/20
shutdown
! interface FastEthernet0/21
shutdown
! interface FastEthernet0/22
shutdown
! interface FastEthernet0/23
shutdown
! interface FastEthernet0/24
shutdown
! interface FastEthernet0/25
shutdown
! interface FastEthernet0/26
shutdown
! interface FastEthernet0/27
shutdown
! interface FastEthernet0/28
shutdown
! interface FastEthernet0/29
shutdown
! interface FastEthernet0/30
shutdown
! interface FastEthernet0/31
shutdown
! interface FastEthernet0/32
shutdown
! interface FastEthernet0/33
shutdown
! interface FastEthernet0/34
shutdown
! interface FastEthernet0/35
shutdown
! interface FastEthernet0/36
shutdown
! interface FastEthernet0/37
shutdown
! interface FastEthernet0/38
shutdown
! interface FastEthernet0/39
shutdown
! interface FastEthernet0/40
shutdown
! interface FastEthernet0/41
shutdown
! interface FastEthernet0/42
shutdown
! interface FastEthernet0/43
shutdown
! interface FastEthernet0/44
shutdown
! interface FastEthernet0/45
shutdown
! interface FastEthernet0/46
description "Fileserver, vlan 42 (revspace)"
switchport access vlan 42
speed 100
duplex full
! interface FastEthernet0/47
description "Uplink naar spoorlaan-d1 Fa0/47"
switchport trunk allowed vlan 1-100,999
speed 100
duplex full
! interface FastEthernet0/48
speed 100
duplex full
! interface GigabitEthernet0/1 ! interface GigabitEthernet0/2 ! interface Vlan1
no ip address
no ip route-cache
shutdown
! interface Vlan5
ip address 10.0.5.11 255.255.255.0
no ip route-cache
! ip default-gateway 10.0.5.1 ip http server logging trap debugging logging 10.0.5.1 snmp-server community rev10 RO banner motd ^CC
            • NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE*******
    (_)        (_)
  /_____\        _____             _____                             /_____\
   |.;.|        |  __ \           / ____|                             |.;.|
   \(%)/        | |__) |_____   _| (___  _ __   __ _  ___ ___         \(%)/
    \_/         |  _  // _ \ \ / /\___ \| '_ \ / _` |/ __/ _ \         \_/
 o=={_}==o      | | \ \  __/\ V / ____) | |_) | (_| | (_|  __/      o=={_}==o
    | |         |_|  \_\___| \_/ |_____/| .__/ \__,_|\___\___|         | |
    | |                                 |_|                            | |
    | |      This system is for the use of authorized HACKERS only!    | |
    | |      So that is probly NOT you. Use of this system without     | |
    | |      prior consent will probably result in an intimate date    | |
    | |      with a lart. Please be adviced that in doubt you are      | |
    | |      probably not skilled enough to proceed and you should     | |
    | |      walk away immediately!                                    | |
 ___|_|___                                                          ___|_|___
^C ! line con 0
stopbits 1
line vty 0 4
login
line vty 5 15
login
! ntp clock-period 17179925 ntp server 91.198.87.118 ! end
