Sensor-data-bridge
| Project sensor-data-bridge | |
| Collects sensor data, forwards it to sensor.community/opensense/etc | |
| Last Update | 2024-02-12 |
What is this
- http://sensor.community (formerly Luftdaten),
- http://opensensemap.org and
https://cayenne.mydevices.com
Project on Github: https://github.com/bertrik/sensor-data-bridge
Features
- Picks up particulate matter measurement data received through TheThingsNetwork, using their "v3" infrastructure
- Forwards measurement data to https://sensor.community
- Forwards measurement data to https://opensensemap.org, you can configure the opensense-id by adding a device attribute in TheThingsNetwork console
- Forwards measurement data to https://cayenne.mydevices.com, you configure the username/password/clientid by adding a device attribute in TheThingsNetwork console
- Supports Cayenne payload format for the data encoding, a custom payload format for SPS30 data (includes particle counts)
- Supports JSON payload format for the data encoding, you can specify in the config file which JSON fields are used
- Handles particulate matter data (PM10, PM4.0, PM2.5, PM1.0), temperature, humidity, barometric pressure
- Handles sound/noise data (LA EQ, and min/max value)
- Can be run as a systemd service, so it automatically restarts in case the software would crash
- add support for geolocation through a scan of surrounding WiFi access-points and a geolocation service (google, mozilla), see h
- add support for NB-IOT modem with t-mobile backend, see my Sim7020 project
- add support for other backends, e.g. feinstaub-app?
Requirements
You need the following:
- a Java installation (JDK to compile), at least version 8
Compilation
To compile the software:
git clone https://github.com/bertrik/sensor-data-bridge.git
- enter the application directory
cd sensor-data-bridge
- run the gradle script to build the software (Linux):
./gradlew assemble
or (Windows):
gradlew assemble
- the application zip & tar is now available in sensor-data-bridge/sensor-data-bridge/build/distributions
git pull
Installation
cd tar xvf code/sensor-data-bridge/sensor-data-bridge/build/distributions/sensor-data-bridge.tar
Configuration
Node configuration
- PM4.0 is encoded as analog value on channel 4 (optional)
The SPS30 produces mass concentration data in 4 categories, particle count in 5 categories, plus particle size. Format:
- 16-bit (big endian) PM1.0 mass concentration (unit 0.1)
- 16-bit (big endian) PM2.5 mass concentration (unit 0.1)
- 16-bit (big endian) PM4.0 mass concentration (unit 0.1)
- 16-bit (big endian) PM10 mass concentration (unit 0.1)
- 16-bit (big endian) PM0.5 number concentration (unit 1)
- 16-bit (big endian) PM1.0 number concentration (unit 1)
- 16-bit (big endian) PM2.5 number concentration (unit 1)
- 16-bit (big endian) PM4.0 number concentration (unit 1)
- 16-bit (big endian) PM10 number concentration (unit 1)
- 16-bit (big endian) typical particle size (unit nm)
A total of 20 bytes. This is sent on LoRaWAN port 30. Temperature and humidity is not encoded.
In case your node uses a payload decoder in the TTN console, you can configure the sensor-data-bridge with the name of the JSON property:
- 'path' is a pointer inside the decoded JSON payload that contains the value, e.g. "lc/avg"
- 'item' is an internal id in the sensor-data-bridge, e.g. "PM10", see https://github.com/bertrik/sensor-data-bridge/blob/master/sensor-data-bridge/src/main/java/nl/bertriksikken/pm/ESensorItem.java
- Within the application you need a 'device', so create a new one, or use an existing one:
- Use OTAA, LoRaMac version 1.0.3
- You need an API key
- Create this on the TTN console, grant individual rights as shown in the screenshot
Configuration
To configure the application:
cd sensor-data-bridge bin/sensor-data-bridge (ctrl-C)
- Edit the configuration YAML file, example:
ttn:
identity_server_timeout: 20
apps:
- name: "particulatematter"
key: "NNSXS......."
encoding: "CAYENNE"
senscom:
timeout: 20
opensense:
timeout: 20
So:
Sensor.community
TODO
- Register a node with id 'TTN-<device-EUI-as-shown-on-display>' (without the spaces or hyphens, e.g. 'TTN-0000547AF1BF713C')
- In the TTN console, add a device attribute with name 'senscom-id' and value 'TTN-<device-EUI-as-shown-on-display>'
Opensensemap
- Go to opensensemap.org and log in
- Create an opensense node with the proper configuration
- Copy the opensensenmap 'box id', a long hexadecimal string
- Add an attribute for the device, under 'General settings', name = 'opensense-id', value = boxid that you copied from opensensemap.org
- The mapping from TTN-id to boxid is refreshed by the forwarder once an hour, so within an hour the forwarding to opensensemap.org starts
Cayenne myDevices
- Go to https://cayenne.mydevices.com/ and log in
- Add a new node, TODO
- Go to TTN console and log in
- Add attributes for the device, under 'General settings'
- attribute name = 'mydevices-username', value = MQTT username from cayenne mydevices dashboard
- attribute name = 'mydevices-password', value = MQTT password from cayenne mydevices dashboard
- attribute name = 'mydevices-clientid', value = Client ID from cayenne mydevices dashboard
Insert non-formatted text here== Development ==
Running with docker / podman
(experimental)
How to run in docker:
- Install docker and docker-compose and add your user account to the 'docker' group (Linux):
sudo apt install docker-ce docker-compose sudo usermod -aG docker <username>
- Get the code from github:
- Enter the 'docker' directory and pull the docker image from github:
cd sensor-data-bridge cd docker docker-compose pull
- Edit the config files with your own settings:
vi sensor-data-bridge.yaml
- Start the container:
docker-compose up
Forwarding noise data
- Three values are sent in the JSON to sensor.community:
- "noise_LAeq", value in dB(A)
- "noise_LA_min", value in dB(A)
- "noise_LA_max", value in dB(A)
- call to dnms_calculate_leq()
- call to dnms_read_data_ready(&data_ready) returns 0 if OK and (data_ready != 0)
- call to dnms_read_leq(&dnms_values) returns 0 if OK
- firmware applies a "correction" by adding a fixed offset
References:
- DNMS is read at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/airrohr-firmware.ino#L3392
- DNMS is formatted in the JSON at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/airrohr-firmware.ino#L3405
- DNMS I2C code is at https://github.com/opendata-stuttgart/sensors-software/blob/beta/airrohr-firmware/dnms_i2c.cpp
