Sensor-data-bridge
Project LoraLuftdatenForwarder
LoRaWAN forwarder for particulate matter data
Last Update 2021-03-07
What is this
This is a Java application that sends airborne particulate matter measurement data from TheThingsNetwork and forwards it to sensor.community (formerly Luftdaten).
It is used in combination with my LoraWanDustSensor: the sensor sends measurement data to TheThingsNetwork, this application picks up the data from TheThingsNetwork and forwards it to sensor.community and to opensensemap.org.
Requirements
You need the following:
  • a Java installation (JDK to compile), at least version 8
Compilation
To compile the software:
  • enter the LoraLuftdatenForwarder/gradle directory
  • run the gradle script to build the software:
 ./gradlew assemble
  • the application zip is now available in LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions
 git pull
Installation
 cd
 tar xvf code/LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions/LoraLuftdatenForwarder.tar
Configuration
Device side
TheThingsNetwork
  • Within the application, ou need a 'device', create a new one, or use an existing one:
    • OTAA
    • Use the application keys as specified in my [[1]] page
  • You need an API key
    • Create this on the TTN console, for now just create a key that grants all rights
This application
To configure the application:
 bin/LoraLuftdatenForwarder
 (ctrl-C)
  • Edit the loraluftdatenforwarder.yaml file, example:
ttn:
  mqtt_url_v2: "tcp://eu.thethings.network"
  mqtt_url_v3: "tcp://eu1.cloud.thethings.network"
  identity_server_timeout: 20
  apps:
  - name: "particulatematter"
    version: "V3"
    key: "NNSXS......."
    encoding: "CAYENNE"
luftdaten:
  timeout: 20
opensense:
  timeout: 20
  ids:
    "0ttn-deveui-here": "put-opensense-boxid-here"
    "0004A30B001E00BE": "5eca4a0fd0545b001c0e5d46"
So:
Sensor.community
TODO
  • Register a node with id 'TTN-<device-EUI-as-shown-on-display>'
Opensensemap
TODO
  • Create a node with the proper configuration
  • Copy the opensensenmap 'box id'
  • Add an attribute in the TTN console:
    • Go to the TTN console, General settings of the device
    • Add attribute, name = 'opensense-id', value = box id that you just copied
  • The boxid should be picked up automatically by the forwarder, within an hour
