ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Contact Mahjongg
Last Update 2019-10-02
My ZX81+35, ZX-81 clone, previously called the ZX14m ZX15, and ZX81+34 (2015 Version) retro homecomputer is a much improved Sinclair ZX81 [1] clone built with the modern materials techniques and components of 2015. The ZX81+35 will be first built and tested in 2016.
As for now comments and questions on the design can be made here [3] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+35
  • wilf rigters "turbo.pdf"
  • wilf rigters "ZX81WAIt.pdf"
  • Other ZX80 /ZX81 info:
  • "Microace_Diagram_s1.jpg"
  • "ZX81CCP_schematic.jpg"
  • "tk82 (ZX81 clone) schemas"
3D Preview of early ZX81+34
Schematic 81+34
Layout ZX81+34
Keyboard for ZX81+34/35
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
This website has developed a problem; redirects with "+" sign in the filename no longer work! I have replaced the latest pictures and .PDF files with ones that use "plus" instead of the + character. The web master is aware of the problem, and he has renamed a few pages, so you can at least visit my two projects that had a + in the filename. Hopefully the problem will be resolved soon, probably by replacing each "+" in an URL to a .PDF by "plus". On November 3 I managed to change the filenames pointing to .PDF's (and a few other non picture formats) in this and the other affected pages to versions with "plus" instead of "+", in the hope that the webmaster will come through with his promise to do the same for these files, so the pointers do point to a valid location once more. doing that to URL's pointing to .PNG pictures might be trickier as changing the URL may delete the picture itself in this thread, until the pictures URL is also changed. So for now I only replaced URL's not used in pictures. until i'm informed the pictures are copied to ones using "plus" instead of "+" in their filename. There was also the case of another page like this, (https://revspace.nl/Zx81plus34) a predecessor of this page talking about why I wanted to create the ZX81 clone that could not be accessed because it also had a "+" in the file name, but I managed to copy it to a new version with plus in the file name instead of + without help from the web master, its here [5]
2017 has arrived
it now includes:
to come (I'm working on it):
  • Keyboard PCB layout
Someone attended me that the component overview drawing contains an error. U13 is listed as a 74HC32, while in fact its a 74HC00. Also there is a problem with downloading the BOM spreadsheet. Both problems will be fixed soon.
