Luteijn/Vortex
Project "Vortex":
Project Luteijn/Vortex | |
Contact | Luteijn |
Last Update | 2018-01-30 |
I've got a four DFRobot 'Vortex' units. Basic programming via the official apps is possible, but rather limited. Luckily, the internal Arduino clone can be directly programmed too. Unfortunately, not all the specs are available, but there are some examples to work with, although they have a quite a bit of 'magic numbers' in them.
Motor Control
still to be documented but seems to be explained fine on the website
LEDs
FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS);
IR obstacle detector
Seems to be somewhat flaky. Needs a bit more work.
- define NUM_LEDS 12
// Data pin that led data will be written out over
- define DATA_PIN 13
CRGB leds[NUM_LEDS];
- define IR_IN 7//IR receiver pin
- define L_IR 8 //left ir transmitter pin
- define R_IR 12 //right ir transmitter pin
int count;
int i; for(i=0;i<24;i++){ digitalWrite(L_IR,LOW); delayMicroseconds(8); digitalWrite(L_IR,HIGH); delayMicroseconds(8); }
} void rightSend38KHZ(void){//right ir transmitter sends 38kHZ pulse
int i; for(i=0;i<24;i++){ digitalWrite(R_IR,LOW); delayMicroseconds(8); digitalWrite(R_IR,HIGH); delayMicroseconds(8); }
PCICR |= 1 << PCIE2; PCMSK2 |= 1 << PCINT23; //pin D7 is int23
count++;
void obstacleAvoidance(void){
char i; count=0; leds[5] = CRGB::Green; FastLED.show(); for(i=0;i<20;i++){ //left transmitter sends 20 pulses leftSend38KHZ(); delayMicroseconds(600); } if(count>10){//if recieved a lot pulse , it means there's a obstacle leds[5] = CRGB::White; FastLED.show(); Serial.println("Left"); delay(100); } count=0; leds[3] = CRGB::Green; FastLED.show(); for(i=0;i<20;i++){//right transmitter sends 20 pulses rightSend38KHZ(); delayMicroseconds(600); } if(count>10){//if recieved a lot pulse , it means there's a obstacle leds[3] = CRGB::White; FastLED.show(); Serial.println("Right"); delay(100); } delay(600);
void setup(void){
delay(2000); FastLED.addLeds<WS2811, DATA_PIN, GRB>(leds, NUM_LEDS); pinMode(L_IR,OUTPUT);//init the left transmitter pin pinMode(R_IR,OUTPUT);//init the right transmitter pin pinMode(IR_IN,INPUT);//init the ir receiver pin Serial.begin(9600); leds[4] = CRGB::Blue; FastLED.show(); delay(2000); leds[4] = CRGB::Purple; FastLED.show(); noInterrupts(); pcint0Init(); interrupts(); //enable the interrupt
void loop(void){
obstacleAvoidance();
MP3-player
There is an MP3.player integrated in the robot. It can be controlled by sending more or less magic commands over software Serial via pin 11. Pin 2 might be connected to the player too, but my tests so far never had anything received there (like an end of song reached, or even just an 'ack').
An example found on the DFRobot site:
#define MP3_VOLUME 0x10 #define TX 11 #define RX 2 #include <SoftwareSerial.h> SoftwareSerial mySerial(RX, TX);// RX, TX void setup() { delay(1000); mp3Init(); mp3setVolume(30);//0~255 } void loop() { mp3player(1); delay(2000); mp3stop(); delay(1000); } void mp3Init() { mySerial.begin (9600); } void mp3setVolume(byte vol) { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x06, 0x00, 0x00, vol, 0xef}; mySerial.write(buffer, 8); delay(20); } void mp3player(byte data) { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x03, 0x00, 0x00, data, 0xef}; mySerial.write(buffer, 8); delay(20); } void mp3stop() { uint8_t buffer[] = {0x7e, 0xff, 0x06, 0x16, 0x00, 0x00, 0x00, 0xef}; mySerial.write(buffer, 8); }
Eyes
Besides 35 predefined eye patterns, it is also possible to upload your own eye patterns.
#include <Wire.h> #define I2C_LED_ADDRESS 0b1100000 #define I2C_WRITE 0x00 uint8_t serial=0; void setup(){ Wire.begin(); // join i2c bus (address optional for master) defined_eyes(6,1); delay(2000); } void loop(){ defined_eyes(1,serial); serial++; if(serial>=35) serial=0; delay(250); } void defined_eyes(uint8_t color,uint8_t serial) { Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4 Wire.write(color&0x07); // color bits: 1 blue, 2 green, 4 red Wire.write(serial); //preset eyes 0~34 Wire.endTransmission(); // stop transmitting }
void custom_eyes(uint8_t color, uint8_t eyeline[10]){ uint8_t index; // right eye left eye //1 2 3 4 5 25 24 23 22 21 //6 7 8 9 10 20 19 18 17 16 //11 12 13 14 15 15 14 13 12 11 //16 17 18 19 20 10 9 8 7 6 //21 22 23 24 25 5 4 3 2 1 Wire.beginTransmission(I2C_LED_ADDRESS << 1 | I2C_WRITE); // transmit to device #4 Wire.write(0x55); // color 55=custom eyes follow Wire.write(0xAA); // ?? AA=color followed by 10 bytes, each defining one line // other values cause eyes to light up in multiple colors, needs more work Wire.write(color&0x7); //color 1-B,2-G,4-R of foreground for (index=0;index<10;index++) { Wire.write(eyeline[index]); } Wire.endTransmission(); // stop transmitting void example_eyes() { /* left eye of robot (right for onlooker) */ Wire.write(0x1f); // bottom row, all bits lit Wire.write(0x1e); // 10 9 8 7 on, 6 off Wire.write(0x1c); Wire.write(0x18); Wire.write(0x10); /* right eye of robot (left for onlooker) */ Wire.write(0x1f); // top row all 5 bits lit Wire.write(0x0f); // leds 6,7,8,9 on 10 off Wire.write(0x07); // 11,12,13 on, 14,15 off Wire.write(0x03); Wire.write(0x01); }
