UMD
Project UMD | |
Under Monitor Display hacks | |
Contact | Eightdot, Sebastius |
Last Update | 2016-11-19 |
todo
on Host
stty -F /dev/ttyUSB0 115200
C code:
./test CD 01 05 ff `echo Hoi RevSpace | perl -nle'print join " ", unpack("H*", $_) =~ /(..)/g'` > /dev/ttyUSB0
Perl code:
perl test.pl "Hoi RevSpace" > /dev/ttyUSB0
C code
#include <stdio.h> #include <stdlib.h> unsigned short crctbl[]={ 0x0000, 0x1189, 0x2312, 0x329b, 0x4624, 0x57ad, 0x6536, 0x74bf, 0x8c48, 0x9dc1, 0xaf5a, 0xbed3, 0xca6c, 0xdbe5, 0xe97e, 0xf8f7, 0x1081, 0x0108, 0x3393, 0x221a, 0x56a5, 0x472c, 0x75b7, 0x643e, 0x9cc9, 0x8d40, 0xbfdb, 0xae52, 0xdaed, 0xcb64, 0xf9ff, 0xe876, 0x2102, 0x308b, 0x0210, 0x1399, 0x6726, 0x76af, 0x4434, 0x55bd, 0xad4a, 0xbcc3, 0x8e58, 0x9fd1, 0xeb6e, 0xfae7, 0xc87c, 0xd9f5, 0x3183, 0x200a, 0x1291, 0x0318, 0x77a7, 0x662e, 0x54b5, 0x453c, 0xbdcb, 0xac42, 0x9ed9, 0x8f50, 0xfbef, 0xea66, 0xd8fd, 0xc974, 0x4204, 0x538d, 0x6116, 0x709f, 0x0420, 0x15a9, 0x2732, 0x36bb, 0xce4c, 0xdfc5, 0xed5e, 0xfcd7, 0x8868, 0x99e1, 0xab7a, 0xbaf3, 0x5285, 0x430c, 0x7197, 0x601e, 0x14a1, 0x0528, 0x37b3, 0x263a, 0xdecd, 0xcf44, 0xfddf, 0xec56, 0x98e9, 0x8960, 0xbbfb, 0xaa72, 0x6306, 0x728f, 0x4014, 0x519d, 0x2522, 0x34ab, 0x0630, 0x17b9, 0xef4e, 0xfec7, 0xcc5c, 0xddd5, 0xa96a, 0xb8e3, 0x8a78, 0x9bf1, 0x7387, 0x620e, 0x5095, 0x411c, 0x35a3, 0x242a, 0x16b1, 0x0738, 0xffcf, 0xee46, 0xdcdd, 0xcd54, 0xb9eb, 0xa862, 0x9af9, 0x8b70, 0x8408, 0x9581, 0xa71a, 0xb693, 0xc22c, 0xd3a5, 0xe13e, 0xf0b7, 0x0840, 0x19c9, 0x2b52, 0x3adb, 0x4e64, 0x5fed, 0x6d76, 0x7cff, 0x9489, 0x8500, 0xb79b, 0xa612, 0xd2ad, 0xc324, 0xf1bf, 0xe036, 0x18c1, 0x0948, 0x3bd3, 0x2a5a, 0x5ee5, 0x4f6c, 0x7df7, 0x6c7e, 0xa50a, 0xb483, 0x8618, 0x9791, 0xe32e, 0xf2a7, 0xc03c, 0xd1b5, 0x2942, 0x38cb, 0x0a50, 0x1bd9, 0x6f66, 0x7eef, 0x4c74, 0x5dfd, 0xb58b, 0xa402, 0x9699, 0x8710, 0xf3af, 0xe226, 0xd0bd, 0xc134, 0x39c3, 0x284a, 0x1ad1, 0x0b58, 0x7fe7, 0x6e6e, 0x5cf5, 0x4d7c, 0xc60c, 0xd785, 0xe51e, 0xf497, 0x8028, 0x91a1, 0xa33a, 0xb2b3, 0x4a44, 0x5bcd, 0x6956, 0x78df, 0x0c60, 0x1de9, 0x2f72, 0x3efb, 0xd68d, 0xc704, 0xf59f, 0xe416, 0x90a9, 0x8120, 0xb3bb, 0xa232, 0x5ac5, 0x4b4c, 0x79d7, 0x685e, 0x1ce1, 0x0d68, 0x3ff3, 0x2e7a, 0xe70e, 0xf687, 0xc41c, 0xd595, 0xa12a, 0xb0a3, 0x8238, 0x93b1, 0x6b46, 0x7acf, 0x4854, 0x59dd, 0x2d62, 0x3ceb, 0x0e70, 0x1ff9, 0xf78f, 0xe606, 0xd49d, 0xc514, 0xb1ab, 0xa022, 0x92b9, 0x8330, 0x7bc7, 0x6a4e, 0x58d5, 0x495c, 0x3de3, 0x2c6a, 0x1ef1, 0x0f78 }; unsigned short docrc(unsigned short crci,unsigned char data) { unsigned short idx,crc; crc=crci; idx = (crc ^ data) & 0xff; crc >>=8; crc ^= crctbl[idx]; return crc; } int main(int argc, char ** argv) { int i,len=1; unsigned char buffer[512]; unsigned char tmp; unsigned short crc=0xffff; buffer[0]=0xfe; for (i=1;i<argc;i++) { tmp=strtol(argv[i],NULL,16); crc=docrc(crc,tmp); if((tmp==0xff) || (tmp==0xfe) || (tmp==0xfd)) { buffer[len++]=0xfd; tmp ^= 0x20; } buffer[len++]=tmp; //printf("%04x\n",crc); } tmp=crc ^ 0xff; if((tmp==0xff) || (tmp==0xfe) || (tmp==0xfd)) { buffer[len++]=0xfd; tmp ^= 0x20; } buffer[len++]=tmp; tmp=(crc>>8) ^ 0xff; if((tmp==0xff) || (tmp==0xfe) || (tmp==0xfd)) { buffer[len++]=0xfd; tmp ^= 0x20; } buffer[len++]=tmp; buffer[len++]=0xff; for(i=0;i<len;i++) { //printf("%02x ",buffer[i]); printf("%c",buffer[i]); } //printf("\n"); crc=docrc(crc,crc ^ 0xff); //printf("%04x\n",crc); crc=docrc(crc,tmp); //printf("%04x\n",crc); return 0; }
Equivalente Perlcode
#!/usr/bin/perl -w use strict; use Digest::CRC; my $crc = Digest::CRC->new( width => 16, init => 0xffff, xorout => 0, refout => 1, poly => 0x1021, refin => 1, cont => 1 ); my $text = shift; my $command = "\xcd\x01\x05\xff$text"; $crc->add($command); my $checksum = "\xff\xff" ^ pack "v", $crc->digest; $command .= $checksum; $command =~ s/([\xfd-\xff])/"\xfd" . ($1 ^ "\x20")/ge; my $packet = "\xfe$command\xff"; print $packet;
Protocol
bootloader (in EPROM)
starts program download if: address == 0xFE || flash[5] !=0x23 || //programmed after rest of flash flash[6] !=0xff //programmed to 0 by appication before //reboot to request download max 0x200 bytes/?message? 0xFD escape, next byte ^= 0x20 0xFE message start 0xFF message end crc16_<<ccitt?>> over unescaped data, including crc bytes should give 0xf0B8 message: +0 ? +1 0x05 +2 0x02 erase " 0x05 program " 0x0a done +3 program: address low +5 program: address high +7 program: data (len = messagelen-7)
application (in FLASH)
0xFD escape, next byte ^= 0x20 0xFE message start 0xFF message end crc16_<<ccitt?>> over unescaped data, including crc bytes should give 0xf0B8 message: +0 0xFF bootload, writes 0x00 to flash[0x6], then reboots +1 0x05 ? must be 0x05 +2 0x01 ? must be 0x01 +3 swver must be 0xffff or >= flash[0xE] (=0x0504 = v4.5) +5 hwver must be flash[0x14] (=0x03) message: +0 0x02 update bit_buf +1 data (len=msg_size-1; max 0x400) message: +0 0xDB broadcast ? +1 0x01 set telly? (note: no reset) +2 idx bit to set ? message: +0 0xCD unicast ? +1 0xFF to all ? +2 0x02 bitbus set bytes +3 offs +5 data " 0x05 set str by id +3 id +5 str " 0x07 see 0x0c " 0x0c cpy? 3E80 by id +3 id +5 data (words) " 0x0d update str by id +3 id +5 str +0 0xCD unicast ? +1 addr must be my_addr (canot be 0xff) +2 0x01 ? len==0x4 ? clr ? +3 idx strobj.len=0 " 0x01 ? len!=0x4 ? clr ? +3 idx +4 pos +8 len " 0x02 set stridx id +3 str_idx +4 id " 0x04 set strobj flags +3 idx +4 val &03 font (0,1 valid 2,3 invalid) &08 dimm &10 inverse video &20 left al. &40 right al. &84 ?? " 0x05 set strobj string +3 idx +4..14 string " 0x07 see 0x0c " 0x09 cpy ? idx=myaddr? +3 data (words) " 0x0a set displ_map_bright? +3 val " 0x0b set telly bits? +3 idx +4 data (dwords) " 0x0c ?cpy? +3 idx +4 data (words) " 0x0d set stings +3 idx +4 strings (0 sep) " 0x0e set substr bitidxmap +3 str_idx +4 data (words) " 0x0f set substr idxs +3 str_idx +4 data
fonts
Font0
Font1
