Spoorlaan-b1
Revision as of 18:11, 22 November 2015 by FooBar (talk | contribs)
Config Summary
  • p1: Empty
  • p2: "Router" (Algemene gateway) (Router gebouw B) VLAN 5,11-99
  • p3: Huurder VLAN 11
  • p4: Huurder VLAN 12
  • p5: Huurder VLAN 13
  • p6: Huurder VLAN 14
  • p7: Huurder VLAN 15
  • p8: Huurder VLAN 16
  • p9: Huurder VLAN 17
  • p10: Huurder VLAN 18
  • p11: Huurder VLAN 19 (Link naar sparkshack2 (tijdelijk))
  • p12: Huurder VLAN 20
  • p13: Huurder VLAN 21
  • p14: Huurder VLAN 22
  • p15: Huurder VLAN 23
  • p16-45: Down/Unused
  • p46: Vlan 42, unused (revspace)
  • p47: Trunk/Uplink naar gebouw D / 'gateway'
  • p48: Unused
  • g1/g2: Fiber poorten, unused
Config
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname spoorlaan-b1
enable password 7 XXXXXXXXXXXXXXXXXXX
clock timezone GMT+1 1
clock summer-time GMT+1 recurring
ip subnet-zero
ip name-server 10.0.5.1
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
spanning-tree extend system-id
spanning-tree vlan 1-4094 priority 4096
interface Port-channel1
interface FastEthernet0/1
 description "Revspace management"
 switchport access vlan 10
 switchport mode access
 logging event spanning-tree
 logging event status
 shutdown
interface FastEthernet0/2
 description "Gateway (Spoorlaan B)"
 switchport trunk allowed vlan 5,11-99
 switchport mode trunk
 speed 100
 spanning-tree portfast
interface FastEthernet0/3
 description "VLAN 11 10.0.11.0/24"
 switchport access vlan 11
interface FastEthernet0/4
 description "VLAN 12 10.0.12.0/24"
 switchport access vlan 12
interface FastEthernet0/5
 description "VLAN 13 10.0.13.0/24"
 switchport access vlan 13
interface FastEthernet0/6
 description "VLAN 14 10.0.14.0/24"
 switchport access vlan 14
interface FastEthernet0/7
 description "VLAN 15 10.0.15.0/24"
 switchport access vlan 15
interface FastEthernet0/8
 description "VLAN 16 10.0.16.0/24"
 switchport access vlan 16
interface FastEthernet0/9
 description "VLAN 17 10.0.17.0/24"
 switchport access vlan 17
interface FastEthernet0/10
 description "VLAN 18 10.0.18.0/24"
 switchport access vlan 18
interface FastEthernet0/11
 description "VLAN 19 10.0.19.0/24"
 switchport access vlan 19
interface FastEthernet0/12
 description "VLAN 20 10.0.20.0/24"
 switchport access vlan 20
interface FastEthernet0/13
 description "VLAN 21 10.0.21.0/24"
 switchport access vlan 21
interface FastEthernet0/14
 description "VLAN 22 10.0.22.0/24"
 switchport access vlan 22
interface FastEthernet0/15
 description "VLAN 23 10.0.23.0/24"
 switchport access vlan 23
interface FastEthernet0/16
 shutdown
interface FastEthernet0/17
 shutdown
interface FastEthernet0/18
 shutdown
interface FastEthernet0/19
 shutdown
interface FastEthernet0/20
 shutdown
interface FastEthernet0/21
 shutdown
interface FastEthernet0/22
 shutdown
interface FastEthernet0/23
 shutdown
interface FastEthernet0/24
 shutdown
interface FastEthernet0/25
 shutdown
interface FastEthernet0/26
 shutdown
interface FastEthernet0/27
 shutdown
interface FastEthernet0/28
 shutdown
interface FastEthernet0/29
 shutdown
interface FastEthernet0/30
 shutdown
interface FastEthernet0/31
 shutdown
interface FastEthernet0/32
 shutdown
interface FastEthernet0/33
 shutdown
interface FastEthernet0/34
 shutdown
interface FastEthernet0/35
 shutdown
interface FastEthernet0/36
 shutdown
interface FastEthernet0/37
 shutdown
interface FastEthernet0/38
 shutdown
interface FastEthernet0/39
 shutdown
interface FastEthernet0/40
 shutdown
interface FastEthernet0/41
 shutdown
interface FastEthernet0/42
 shutdown
interface FastEthernet0/43
 shutdown
interface FastEthernet0/44
 shutdown
interface FastEthernet0/45
 shutdown
interface FastEthernet0/46
 description "Fileserver, vlan 42 (revspace)"
 switchport access vlan 42
 speed 100
 duplex full
interface FastEthernet0/47
 description "Uplink naar spoorlaan-d1 Fa0/47"
 switchport trunk allowed vlan 1-100,999
 speed 100
 duplex full
interface FastEthernet0/48
 speed 100
 duplex full
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan5
 ip address 10.0.5.11 255.255.255.0
 no ip route-cache
ip default-gateway 10.0.5.1
ip http server
logging trap debugging
logging 10.0.5.1
snmp-server community rev10 RO
banner motd ^CC
******NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE****NOTICE*******
     (_)        (_)
   /_____\        _____             _____                             /_____\
    |.;.|        |  __ \           / ____|                             |.;.|
    \(%)/        | |__) |_____   _| (___  _ __   __ _  ___ ___         \(%)/
     \_/         |  _  // _ \ \ / /\___ \| '_ \ / _` |/ __/ _ \         \_/
  o=={_}==o      | | \ \  __/\ V / ____) | |_) | (_| | (_|  __/      o=={_}==o
     | |         |_|  \_\___| \_/ |_____/| .__/ \__,_|\___\___|         | |
     | |                                 |_|                            | |
     | |      This system is for the use of authorized HACKERS only!    | |
     | |      So that is probly NOT you. Use of this system without     | |
     | |      prior consent will probably result in an intimate date    | |
     | |      with a lart. Please be adviced that in doubt you are      | |
     | |      probably not skilled enough to proceed and you should     | |
     | |      walk away immediately!                                    | |
  ___|_|___                                                          ___|_|___
^C
line con 0
 stopbits 1
line vty 0 4
 login
line vty 5 15
 login
ntp clock-period 17179925
ntp server 91.198.87.118
end
