Reflow Oven
Revision as of 21:15, 30 June 2015 by Crashjuh (talk | contribs)
Project Reflow Oven
Contact User:Crashjuh, smeding, robv
Last Update 2015-06-30
Because modern electronics components are tending more and more towards becoming SMD-only, and because the associated size reduction can also be very useful for space projects, we need a reflow oven.
Oven has been acquired. It is a cheap 1kW Everglades toaster oven and has been able to do very crude reflow. A prototype for the controller has been built and successfully measures temperature. I (smeding) am currently hammering out the PID loop to keep it at a fixed temperature. After that, all it needs is a little bit of UI and we should be good to go.
We now have a real reflow oven and currently we are testing what the best settings are. Over time, these data are reported here.
Use by Revspace
The oven has 10 memory locations (Program number 01 till 10). At the moment we only have programmed program number 01. We program the programs for different PCB thicknesses.
Program number PCB Thickness 01 1.5 / 1.6 mm
Program number: Enter : 01
Preheat standby: Enter : 080
Preheat airtemp: Enter : 150
Preheat time: Enter : 02:00
Solder temp. : Enter : 250
Solder time: Enter : 01:30
