BT785
Project BT785
Connecting a BT785 EC meter to raspberry pi
Last Update 2025-10-12
This page is about reverse engineering the BT-785, an inexpensive Tuya-compatible water electrical conductivity (EC) meter. It measures EC and temperature, and has a display and communicates its reading over Bluetooth Low-Energy (BLE) to the Tuya app on a phone. The goal is to understand the communication protocol so we can communicate with it from the raspberry pi in the Karaburan project.
Analysis
BLE characteristics in NRF-connect
On the lowest level, it uses bluetooth low-level with the GATT profile on the right:
Most important seem two characteristics:
  • 00000002-0000-1001-8001-00805f9b07d0: module to phone, notifies of data from the EC meter
  • 00000001-0000-1001-8001-00805f9b07d0: phone to module, we write data to the EC meter
The device connects to the Tuya app on a phone. Data transfer is encrypted.
While the tuya app is running, we can see notifications coming in, for example:
00 31 46 05 36 46 B1 F5 36 55 B2 56 34 E1 B3 C9
13 33 0A D9 17 E8 FE 4F 5C 9A 70 CE DB 26 A6 17
22 CC DF 65 7D F7 0D 01 02 0A 33 45 B0 C1 A5 A8
42 F5 C1 B2
Composition of the data:
  • 0x31 is the length of the data
  • 0x46 probably some sequence number
  • 0x05 the "security flag" indicating the type of encryption
  • 36 46 B1 F5 36 55 B2 56 34 E1 B3 C9 13 33 0A D9: 16 bytes of initial vector
  • rest: encrypted data, padded to 16 bytes unit
Another example:
00-31-40-05-8A-8B-20-8F-95-46-06-C0-CF-B2-9C-98
45-F8-E5-0F-8F-43-86-79-CA-1A-11-4B-30-F5-CB-1C
3F-93-3C-41-CE-27-DD-23-82-8A-2A-95-AE-71-4E-BF
DC-50-F2-32
HCI snoop log
Protocol
The protocol has the following steps:
  • Pairing: Initially, when the EC meter is paired with the Tuya app, a key is generated. This key is stored inside the meter and stored in the app. You can register with the Tuya developer console, link your device to the console, and fetch this key. Example key: '<z)o}Ezmuw01.TxQ'. Let's call this the 'local key'.
  • Session start When the EC meter is powered on and communication starts, the session is started by the host sending a 'device info request'. The response contains a session key. This exchange is secured using part of the 'local key' (only 6 bytes!?).
  • Measurement, the device sends measurements as encrypted notifications.
The encrypted frames typically do no fit in basic GATT frames. A GATT notification can typically hold only about 23 bytes of data.
An encrypted frame contains of a 5-byte header, a 16-byte IV, so basically no room left for the actual data.
I see in the app-device communication that the MTU is increased before session start:
BLE MTU negotiation
Pairing
I plan to not investigate this, just let the device and the app figure this out, then fetch the local key from the API
Session start
The very first step is probably upping the MTU, since by default GATT only allows very small blocks of data to be exchanged.
The phone sends a device info request: Encrypted, this looks like
00212004
55304552fd7810cdb72cced8831dc514
8b77f23fb840607c58d0beb91c463a98
The device responds with:
0081014004
65db80c3df1cde3aebe8bf8ceee18b39
f2be5ee93a59f09e0c65af2963440497
394317d56482a56e2ed32d05c727585b
980b73b3266e782acb9a7705233c5807
444cacccef3daa3e1eec12c271069a42
9ed448d8312d33212f0a886abaa5cecb
ed8ca761eea1daaef97cd5fc9033fb09
5f08353bf0ae6a7f231ee94df6100ce8
This can be decoded as follows:
  • header says this is a block of 0x81 bytes, sequency number 0x40, with security flag 0x04
  • determine iv = first 16 bytes after the header = 65db80c3df1cde3aebe8bf8ceee18b39
  • calculate key = md5(first 6 bytes of local key) = md5("<z)o}E") = 64ba62ad750c312d08e10aa343769fbf
  • decode remaining bytes using AES in CBC mode with the iv and key just determined
The decoded response is:
00000001000000010000006001020402
1001c4984a2a590f0100c14161b10880
5adba92a221eb39d6e2f000000000000
00000000000000000000000102000100
0001006266366138346d66796b756262
696a3300000000000000000000000000
0000000000e76d694f23dc00755d0202
What we get from this:
  • offset 0x0C, 0102 means: device version 1.2
  • offset 0x0E, 0402 means: protocol version 4.2
  • offset 0x10, 10: flag
  • offset 0x11, 01: is_bind
  • offset 0x12, we find the srand key = 0xc4984a2a590f
Measurement reports
Measurements are sent on the notification characteristic.
Example data:
00314705
09a25c5146e55def691d26bbf80cddc6
7375b68f9c835408df05a2c2301f5a7f
671f46c3be8bb16e3500cda30b1571b7
</per>
Decoded data:
<pre>
