NoiseMeter
Revision as of 08:48, 12 October 2023 by P4r4D0xum (talk | contribs) (Undo revision 31683 by P4r4D0xum (talk))
Project NoiseMeter
Measuring audio noise as citizen science
Status Initializing
Last Update 2023-10-12
This project is about measuring environmental audio noise as citizen science.
For example, noise can be:
  • road traffic noise (cars, mopeds, etc)
  • air traffic noise,
  • industrial noise, like building activities
Existing sound/noise meter projects:
This project is about a kind of clone of the Amsterdam Sounds project.
hardware
Nano33 IOT
Nano33 IOT pinout
Hardware is a nano33 iot board.
Connections
SPH0645 nano33 iot Remark
SEL - leave unconnected
LRCK A2 (16) - I2S FS sample clock
DOUT D4 (4) - I2S SD data
BCLK A3 (17) - I2S SCK bit clock
GND GND
3V 3v3
The software is based on arduino, built using platformio.
Casing
I'm looking into several options:
Junction box
Simple junction boxes sold by Gamma:
A downward pointing hole can be used for an 868 MHz LoRaWAN antenna.
Sensor.community casing
See https://sensor.community/docs/dnms/dnms-noise-measuring-dn40-result.jpg
Dimensions:
  • microphone is on a half inch (12.7 mm OD) white polystyrene pipe, 115 mm long
  • main piece is 25mm, length 160mm
  • some other connecting piecess
"RIVM" test casing
Exact dimensions unknown, see photo on this page: https://samenmeten.nl/nieuws/citizen-science-geluidmetertest-op-rivm-terrein
My guess:
  • microphone is on a 10mm diameter pipe, length 100mm
  • main case is a 40mm diameter pipe, length 200mm
