ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Status completed“completed” staat niet in de lijst met mogelijke waarden voor de eigenschap “Project Status” (Proposed, Initializing, In progress, Completed, Stalled, Abandoned).
Contact Mahjongg
Last Update 2022-04-05
Introduction to the ZX81+35
  • wilf rigters "turbo.pdf"
  • wilf rigters "ZX81WAIt.pdf"
  • Other ZX80 /ZX81 info:
  • "Microace_Diagram_s1.jpg"
  • "ZX81CCP_schematic.jpg"
  • "tk82 (ZX81 clone) schemas"
3D Preview of early ZX81+34
Schematic 81+34
Layout ZX81+34
Keyboard for ZX81+34/35
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
2017 has arrived
it now includes:
to come (I'm working on it):
  • Keyboard PCB layout
10 FOR X = 0 TO 255
20 PRINT CHR$ X;
30 NEXT X
Bestand:ZX81+35 REV 4.2. schematic color.pdf
Bestand:ZX81+35 REV 4.2 layout preview.PDF
