Sensor-data-bridge
Project LoraLuftdatenForwarder
LoRaWAN forwarder for particulate matter data
Last Update 2021-06-16
What is this
Project on Github: https://github.com/bertrik/LoraLuftdatenForwarder
Features
  • Picks up particulate matter measurement data received through TheThingsNetwork, using their "v3" infrastructure
  • Forwards measurement data to https://sensor.community
  • Forwards measurement data to https://opensensemap.org, you can configure the opensense-id by adding a device attribute in TheThingsNetwork console
  • Forwards measurement data to https://cayenne.mydevices.com, you configure the username/password/clientid by adding a device attribute in TheThingsNetwork console
  • Supports Cayenne payload format for the data encoding, a custom payload format for SPS30 data (includes particle counts)
  • Handles particulate matter data (PM10, PM4.0, PM2.5, PM1.0), temperature, humidity, barometric pressure
  • Can be run as a systemd service, so it automatically restarts in case the software would crash
Requirements
You need the following:
  • a Java installation (JDK to compile), at least version 8
Compilation
To compile the software:
  • enter the LoraLuftdatenForwarder/gradle directory
  • run the gradle script to build the software (Linux):
 ./gradlew assemble
or (Windows):
 gradlew assemble
  • the application zip & tar is now available in LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions
 git pull
Installation
 cd
 tar xvf code/LoraLuftdatenForwarder/LoraLuftdatenForwarder/build/distributions/LoraLuftdatenForwarder.tar
Configuration
Node configuration
  • PM4.0 is encoded as analog value on channel 4 (optional)
The SPS30 produces mass concentration data in 4 categories, particle count in 5 categories, plus particle size. Format:
  • 16-bit (big endian) PM1.0 mass concentration (unit 0.1)
  • 16-bit (big endian) PM2.5 mass concentration (unit 0.1)
  • 16-bit (big endian) PM4.0 mass concentration (unit 0.1)
  • 16-bit (big endian) PM10 mass concentration (unit 0.1)
  • 16-bit (big endian) PM0.5 number concentration (unit 1)
  • 16-bit (big endian) PM1.0 number concentration (unit 1)
  • 16-bit (big endian) PM2.5 number concentration (unit 1)
  • 16-bit (big endian) PM4.0 number concentration (unit 1)
  • 16-bit (big endian) PM10 number concentration (unit 1)
  • 16-bit (big endian) typical particle size (unit nm)
A total of 20 bytes. This is sent on LoRaWAN port 30. Temperature and humidity is not encoded.
TTN API key rights
    • Use OTAA, LoRaMac version 1.0.3
  • You need an API key
LoraLuftdatenForwarder configuration
To configure the application:
 bin/LoraLuftdatenForwarder
 (ctrl-C)
  • Edit the loraluftdatenforwarder.yaml file, example:
ttn:
  identity_server_timeout: 20
  apps:
  - name: "particulatematter"
    key: "NNSXS......."
    encoding: "CAYENNE"
luftdaten:
  timeout: 20
opensense:
  timeout: 20
So:
Sensor.community
TODO
  • Register a node with id 'TTN-<device-EUI-as-shown-on-display>' (without the spaces or hyphens, e.g. 'TTN-0000547AF1BF713C')
Opensensemap
  • Go to opensensemap.org and log in
    • Create an opensense node with the proper configuration
    • Copy the opensensenmap 'box id', a long hexadecimal string
    • Add an attribute for the device, under 'General settings', name = 'opensense-id', value = boxid that you copied from opensensemap.org
  • The mapping from TTN-id to boxid is refreshed by the forwarder once an hour, so within an hour the forwarding to opensensemap.org starts
Cayenne myDevices
  • Go to https://cayenne.mydevices.com/ and log in
    • Add a new node, TODO
  • Go to TTN console and log in
    • Add attributes for the device, under 'General settings'
      • attribute name = 'mydevices-username', value = MQTT username from cayenne mydevices dashboard
      • attribute name = 'mydevices-password', value = MQTT password from cayenne mydevices dashboard
      • attribute name = 'mydevices-clientid', value = Client ID from cayenne mydevices dashboard
Work in progress
Forwarding noise data
  • Three values are sent in the JSON to sensor.community:
    • "noise_LAeq", value in dB(A), meaning?
    • "noise_LA_min", value in dB(A), some kind of minimum
    • "noise_LA_max", value in dB(A), some kind of maximum
I think these can be encoded in Cayenne as a simple analog value (which has a range of approximately -327..327 with a resolution of 0.01. Just need to assign a channel number to it.
  • call to dnms_calculate_leq()
  • call to dnms_read_data_ready(&data_ready) returns 0 if OK and (data_ready != 0)
  • call to dnms_read_leq(&dnms_values) returns 0 if OK
  • firmware applies a "correction" by adding a fixed offset
References:
