Spacenet/mobileconfig
Revision as of 23:38, 26 March 2024 by Shiz (talk | contribs) (Shiz moved page Mobileconfig to Spacenet/mobileconfig: Moving within the spacenet namespace)
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>PayloadContent</key>
	<array>
		<dict>
			<key>AutoJoin</key>
			<true/>
			<key>EAPClientConfiguration</key>
			<dict>
				<key>AcceptEAPTypes</key>
				<array>
					<integer>21</integer>
				</array>
				<key>PayloadCertificateAnchorUUID</key>
				<array>
					<string>7060659C-7F19-4F0C-B292-505D8A41E9A9</string>
				</array>
				<key>TTLSInnerAuthentication</key>
				<string>PAP</string>
			</dict>
			<key>EncryptionType</key>
			<string>WPA</string>
			<key>HIDDEN_NETWORK</key>
			<false/>
			<key>IsHotspot</key>
			<false/>
			<key>PayloadDescription</key>
			<string>Configures wireless connectivity settings.</string>
			<key>PayloadDisplayName</key>
			<string>Wi-Fi (spacenet)</string>
			<key>PayloadIdentifier</key>
			<string>com.apple.wifi.managed.DACD46DA-FB49-4B30-AA0E-120A67808D73</string>
			<key>PayloadOrganization</key>
			<string></string>
			<key>PayloadType</key>
			<string>com.apple.wifi.managed</string>
			<key>PayloadUUID</key>
			<string>DACD46DA-FB49-4B30-AA0E-120A67808D73</string>
			<key>PayloadVersion</key>
			<integer>1</integer>
			<key>ProxyType</key>
			<string>None</string>
			<key>SSID_STR</key>
			<string>spacenet</string>
		</dict>
		<dict>
			<key>PayloadCertificateFileName</key>
			<string>revspace-wifi-ca.crt</string>
			<data>
			LS0tLS1CRUdJTiBDRVJUSUZJQ0FURS0tLS0tCk1JSUR6akNDQXJZ
			Q0NRRGFydk5oUkwwaFNUQU5CZ2txaGtpRzl3MEJBUXNGQURDQnFE
			RUxNQWtHQTFVRUJoTUMKVGt3eEN6QUpCZ05WQkFnTUFscElNUkV3
			RHdZRFZRUUhEQWhFWlc0Z1NHRmhaekVqTUNFR0ExVUVDZ3dhVTNS
			cApZMmgwYVc1bklGSmxkbVZzWVhScGIyNGdVM0JoWTJVeEVUQVBC
			Z05WQkFzTUNGSmxkbk53WVdObE1SOHdIUVlEClZRUUREQlptYkhW
			NExuTndZV05sTG5KbGRuTndZV05sTG01c01TQXdIZ1lKS29aSWh2
			Y05BUWtCRmhGaWIyRnkKWkVCeVpYWnpjR0ZqWlM1dWJEQWVGdzB5
			TVRFeU1EUXlNRE0zTlROYUZ3MDBPVEEwTWpBeU1ETTNOVE5hTUlH
			bwpNUXN3Q1FZRFZRUUdFd0pPVERFTE1Ba0dBMVVFQ0F3Q1drZ3hF
			VEFQQmdOVkJBY01DRVJsYmlCSVlXRm5NU013CklRWURWUVFLREJw
			VGRHbGphSFJwYm1jZ1VtVjJaV3hoZEdsdmJpQlRjR0ZqWlRFUk1B
			OEdBMVVFQ3d3SVVtVjIKYzNCaFkyVXhIekFkQmdOVkJBTU1GbVpz
			ZFhndWMzQmhZMlV1Y21WMmMzQmhZMlV1Ym13eElEQWVCZ2txaGtp
			Rwo5dzBCQ1FFV0VXSnZZWEprUUhKbGRuTndZV05sTG01c01JSUJJ
			akFOQmdrcWhraUc5dzBCQVFFRkFBT0NBUThBCk1JSUJDZ0tDQVFF
			QXFlVk9pUFltMUhkRTBiN0V4Z081VDhLQ1pUUnh5TEFhcVBUNnpr
			ZUFWdnVtRm5LYnc2RmIKTlJJY24xUm8vWEQyL1l3TVNVTDJjeXYw
			MnVheVVnaVJnY213YWpmRmhmaW1nWEo5NnVrM3F2QXNPNHBWeTN4
			dgpxZ2VUeTZ5dkVoaXJTQmQ5dThoRU9VMWt4UktUOGlnUUlXSDdj
			aTRLWTZDK1JEZVpsZGYxZnlKbnJPTWk0eU9FCmVaWENDSG9YWTZK
			UE8waU1zMXo1cXk4Rk82VExWTlY4eHRqb3h6TUdPMHp5UzdCZDZ2
			TmI1Q2l5d0svU29nUGcKWU55djQ0ODRrWjR5dkxOMHV1a0RZTWM4
			cFJWb2JNU2Jjb256NWVKMG9sR3pYeGpwNGNSeHBUU1l6QlVvQXZt
			MApOMUJCamp3amhGVHZqMTNITks0N2NYZDVadkhMSDdQREN3SURB
			UUFCTUEwR0NTcUdTSWIzRFFFQkN3VUFBNElCCkFRQWhFWkxKNnhr
			eExaNDAzcDBWRlhON05mMmVuRWVrV08yY2ErcXdLRmRScGhUMDdn
			SUdod0h3d0RGQW0zMWoKSWNCcVZOUFpwLy9pYnVYcXBMVit1Q09D
			Y3JUWStKN0ZYM3ljU0l3L1Y3aVBFSmpBZWY0dmJHMDkvTitPbWkz
			bwo3Q0p1eXp6NGxXYnMwQmQ3U0dNZTF2bFRzV1hBMHZUZUdDU0ND
			UU9XYStpejcwYkFLYzQwVUIrV01EWnh4b3ppCmdhQXllMHB2VTF2
			a00vNlVkVndVNjErMVJOckFFTW4wNFpkZDNFTEI2S1VyZlY5QlR6
			ZnZZb1BJNXRnbDdibW4KdHpPdURkQzU2S0lwM0JFTk5ic3VBY21u
			NVhPcGwxS2FPblM0ejJEanA3RXBObUl6eXZPcmJDbVUrZXhaeU1m
			MgpyUmtvVmw2MWlXdy8reDRYcGliT2F3T0IKLS0tLS1FTkQgQ0VS
			VElGSUNBVEUtLS0tLQo=
			</data>
			<string>Adds a CA root certificate</string>
			<string>flux.space.revspace.nl</string>
			<string>com.apple.security.root.7060659C-7F19-4F0C-B292-505D8A41E9A9</string>
			<string>com.apple.security.root</string>
		</dict>
	</array>
	<string>This profile allows you to connect to the Spacenet wifi.</string>
	<string>revspace</string>
	<string>revspace.wifi</string>
	<string>Revspace</string>
	<key>PayloadRemovalDisallowed</key>
	<false/>
	<string>Configuration</string>
	<string>7CC8815D-0F2D-413B-99C7-B9B9DDD1A300</string>
</dict>
</plist>
