ElectronicsPartsList
Revision as of 17:23, 14 December 2011 by Smeding (talk | contribs) (Table fix. In the long term, the actual information will need to be fixed, too.)
List of electronics parts for the space
TODO: this page is horrendously out of date, someone should do a rough inventory of parts
Resistor 6 series 10 -> 1M (available, somewhat)
Capacitor 6 series 10 -> 1M (available, somewhat)
If the order ID is just a number see Farnell
Part Count Use Order ID Price Available in space
E6 series resistors 1 41.48 | Half a kit left with 10pcs
1kOhm resistor 1/4w 100 One of the most commonly used 1700251 1.1
0.1uF 50V decoupling cap 100 decoupling, common use 1692300 9
10uF 35V decoupling cap 100 decoupling, charge pump, common 9452281 1.7
1N4148 500 small signal diode 368106 2.00
1N4007 100 general purpose high voltage diode (coil supression, etc) 9565051 8.70
1N5226B 50 3.3 volt zener 1700785 3.65
1N5231B 50 5 volt zener 1612371 1.25
MPF 102 50 small JFET 1467954 9,55
BC547 200 small signal NPN BJT, higher voltage then BC558 availible need to count
BC557 200 small signal PNP BJT, higher voltage then BC558 availible need to count
2N2222 100 1611371 4.70
TIP41C 10 power transistor NPN 5A 9804170 7.90
TIP42C 10 power transistor PNP 5A 9804196 7.20
2N3055 10 High power transistors 15A NPN available
MJ2955 5 High power transistor 15A PNP
3,3 V REG, LDO 250MA, TO-92-3 25 1331485 12.75
3,3 V REG, LDO 1.5A, TO-220 25 7208324 5.64
5 V REG, LDO 250MA, TO-92-3 25 1331481 8.5
5 V REG, LDO 1.5 A, TO-220 25 7208324 5.64
MAX232 10 TTL <-> RS232C ? IC 1470445 4.40
741 20 The absolute classic opamp 1564944 3.8
OPA2337 10 General purpose opamp rail-to-rail 1097410 12.20
TL074CN ? 20 Generic 4 in one opamp 9755934 6.4
LM358 10 very linear opamp high gain 1459520 3.7
LM311 20 Comparator 2293183 2.86
DE-9 10 DB-9 150726 6
RJ-45 20 1284342 13.8
2.54mm terminals 2xX breakable male 2 IDE style connector 3418560 6.66
2.54mm terminals 1xX breakable male 4 IDE style connector 1580056 6.12
2 mm terminals 1xX breakable male 1 laptop IDE style connector 672002 3.17
2.54mm terminals 2xX breakable female 2 IDE style connector 1322596 13.56
2.54mm terminals 1xX breakable female 4 IDE style connector 1322595 13.48
2 mm terminals 1xX breakable female 1 laptop IDE style connector 9728937 7.47
Barrel socket, low voltage, 2.1mm 20 Generic power input connector 1216726 14.2
2x AA battery holder 10 10 +/-
9V battery holder 10 10 +/-
100KOhm potmeter 25 available 20 +/-
10KOhm potmeter 25
USB cables (normal, mini, micro, groot voor arduino's, etc..)
ATTiny4313 10 20 pins AVR USBTiny geschikte, maar dan met 4kB flash 1841620 22
ATMega328p 20 same AVR as Arduino uses 1715487 63
ATTiny85 10 8-pins AVR, 8 kB flash 1455162 20.3
ATTiny44 10 14-pins AVR, 4 kB flash 1455150 12.5
MSP430G2231 ? 10 Valueline, identiek aan die in Launchpad 1812192 11.9
Resonator 12Mhz 20 Needed for soft USB 1448128 7
Resonator 16Mhz 10 1448129 3.5
Resonator 20Mhz 30 1448130 10.5
Resonator 10Mhz 10 1448127 3.5
Resonator 8Mhz 10 1448126 3.5
Crystal 32.687kHz 20 Watch crystal 1611828 2.66
USB mini-B 15 1696540 11.4
USB B 15 1308876 6.45
IR LED 940NM, 20° angle, 130mW/Sr 20 1328299 6.4
16x2 HD44780 character display 32 Via SA007 kopen
Darlington Array 7 NPN ULN2003A ? 20 1210973 4.2
Darlington Array 8 NPN ULN2804A ? 10 1047762 5.1
74HC00 quad 2-input NAND 20 380349 3.16
74HC02 quad 2-input NOR 20 380350 3.36
74HC08 quad 2-input AND 20 1013913 5
74HC86 quad 2-input XOR 20 380490 3.36
74HC393 dual 4-bit binary counter 10 380799 4.1
74HC374 8-bit latch 10 380763 2.8
74HC595 8-bit shift register serial to parralel 20 Generic, chainable 3166028 7.6
74HC165 8-bit shift register parralel to serial 20 Generic, chainable 380635 5
NE555 20 9589899 7.2
NE556 20 9589910 5.8
Push button NO wire 30 1634688 20.1
Push button NC wire 10 1634693 7
Push button NO PCB 50 1813631 16.5
SPDT PCB 10 9472983 13.1
SPDT rocker 20 1454380 11.6
mouser
Sockets voor alle ICs xxx Winkelwagentje 37.36
IR LED 940NM, wide angle 1000 Walter betaald Mouser: 638-IR333C/H0/L10 62.00
leds-buy.nl
Prijs van onderstaande is EUR 62.60 :
Part Count *Use* Order ID Available in space
RGB LED 25° 10mm 10 shop link
RGB LED 25° 5mm 25 shop link
RGB LED 90° 5mm 10 shop link
7-segment green 12 shop link
7-segment orange 12 shop link
7-segment red 12 shop link
