ElectronicsMeasurementRig
A lot of electronics measurements use the same equipment: power supply, function generator, oscilloscope.. It makes sense to consolidate this into a single, fixed measurement platform that is already in the workshop and is complete with relevant cables and such.
Current todo
(not necessarily in this order)
- Find or build an enclosure
- Figure out what to put in it
- Think out how to keep the dust out when rig is not in use
- Order what we still need
- Put it together
- Create documentation sheets (as described below)
- PROFIT!
Enclosure
I (smeding) haven't thought about this too much yet but a reasonable idea seems to be a trolley of some sort (or something without wheels) with separate shelves.
Contents
- Power supply
- Oscilloscope
- Function generator
- Bench-top multimeter
- Logic analyzer
- Timer?
- Relevant cables:
- Banana-plug leads, assorted colours - we can manufacture these
- Banana-plug to crocodile clip leads, red & black - we can manufacture these
- Multimeter probes, 1 red / 1 black - we have these
- BNC <-> BNC (50 ohms, semi-decent coax) - to be acquired (possibility)
- BNC <-> crocodile clips - to be acquired (possibility)
- BNC t-junctions - we have these
- 'scope probes - we have these
- Documentation - both simple, single-sheet summaries for beginners (see below) and full manuals where we can find them.
Documentation
The main idea for this part is to write up basic one-sheet introductions to the various instruments at our disposal. Necessary information would be (order isn't fixed):
- What the instrument does (measure voltage, produce a voltage, etc.)
- When to use it
- Limitations
- A walkthrough for doing a measurement (for a 'scope: from "attach probes to device and circuit" to getting the image you want)
- Issues/features specific to the instruments at RevSpace
Devices to cover:
- Power supply
- Multimeter
- Oscilloscope
Todo for this part:
- Writing
- Graphic design, pictures, any artwork (diagrams?) - nothing too fancy, just enough to make it clear
- Put them online and print them
