VoipRadioPanel
Goal
Have max. 6 participants dial on to an asterisk pbx, make each of their voices individually available as a mono output. Each participant should hear the other participants plus an external input from the mixing desk (studio mics / music), but not hear themselves back.
Documentation should be provider for common platforms (linux, macosx, ms windows). Pick one voip client on each platform, and document every step from installation, configuration to connecting to the conference pbx and joining.
Todo
Needs a lot of testing in the field:
- get a bunch of typical users to give up a few hours of their time, explain they will need to be patient and do exactly as we say
- set up a conference bridge with different types of connections: pots, voip, skype to sip gateway
- documentation
- create sample set to guide users in joining the conf
Setup
- ESI u46xl sound card (6 out, 4 in, sponsored by Hxx)
- Mixing desk with at least 6 line-ins, one aux or sub out
- linphone instances to connect to the pbx
- asterisk with custom extensions and scripts
- siptosis skype gateway
ESI u46xl
Linux has crappy support for this device. To initialize the device properly, send the following to the usb mixer with 'amixer -c 1 -s':
cset numid=1 on,on cset numid=2 on cset numid=3 0,0,0,0 cset numid=4 on,on cset numid=1 off,off cset numid=5 off cset numid=1 on,on cset numid=7 on,on,on,on cset numid=8 on cset numid=6 0,0,0,0 cset numid=9 31,31,31,31,31,31
(yes, we turn 1 on, of and on again, needed to properly load 5, which disables monitor)
This .asoundrc makes the channels individually adressable and creates some fake input/output for linphone:
// Copyright (c) Koen Martens, gmc@sonologic.nl
// licensed under GPLv3
pcm.u46xl_play {
type dmix
ipc_key 2048
slave {
pcm "hw:1,0"
rate 44100
period_time 0
period_size 1024
buffer_size 8192
channels 6
bindings {
0 0
1 1
2 2
3 3
4 4
5 5
pcm.out1 {
type plug
slave {
pcm "u46xl_play"
channels 6
rate 44100
ttable.0.0 1
pcm.out2 {
type plug
slave {
pcm "u46xl_play"
channels 6
ttable.0.1 1
pcm.out3 {
type plug
slave {
pcm "u46xl_play"
channels 6
ttable.0.2 1
pcm.out4 {
type plug
slave {
pcm "u46xl_play"
channels 6
ttable.0.3 1
pcm.out5 {
type plug
slave {
pcm "u46xl_play"
channels 6
ttable.0.4 1
pcm.out6 {
type plug
slave {
pcm "u46xl_play"
channels 6
ttable.0.5 1
pcm.u46xl_record {
type dsnoop
ipc_key 1647
slave {
pcm "hw:1,0"
period_size 0
buffer_size 65536
rate 44100
channels 4
bindings {
0 0
1 1
pcm.in1 {
type plug
ttable.0.0 1.0
slave.pcm pcm.u46xl_record
pcm.in2 {
type plug
ttable.0.1 1.0
pcm.in3 {
type plug
ttable.0.2 1.0
pcm.in4 {
type plug
ttable.0.3 1.0
pcm.dummy {
type plug
slave {
pcm default
channels 1
rate 44100
ttable.0.0 0
pcm.mynull {
type null
pcm.channel1 {
type asym
playback.pcm "out1"
capture.pcm "dummy"
pcm.channel2 {
type asym
playback.pcm "out2"
capture.pcm "dummy"
pcm.channel3 {
type asym
playback.pcm "out3"
capture.pcm "dummy"
pcm.channel4 {
type asym
playback.pcm "out4"
capture.pcm "dummy"
pcm.channel5 {
type asym
playback.pcm "out5"
capture.pcm "dummy"
pcm.channel6 {
type asym
playback.pcm "out6"
capture.pcm "dummy"
pcm.feedback {
type asym
playback.pcm "null"
capture.pcm "in1"
linphone
Use linphonec -c configfile -s 'spyext@voip.host', eg:
linphonec -c linphone1.cfg -s '1@pbx.sonologic.net'
Here is linphone1.cfg:
[sound] alsadev=channel1 playback_dev_id=ALSA: channel1 ringer_dev_id=ALSA: channel1 capture_dev_id=ALSA: channel1 remote_ring=/usr/share/sounds/linphone/ringback.wav [GtkUi] advanced_ui=1 [video] device=V4L2: /dev/video0 size=cif enabled=0 display=0 capture=0 show_local=0 self_view=0 [net] download_bw=0 upload_bw=0 firewall_policy=2 mtu=0 stun_server=pbx.sonologic.net [sip] sip_port=5071 guess_hostname=1 inc_timeout=15 use_info=0 use_rfc2833=0 use_ipv6=0 register_only_when_network_is_up=1 default_proxy=-1 contact=<sip:spy@localhost:5071> [rtp] audio_rtp_port=7081 video_rtp_port=9078 audio_jitt_comp=60 video_jitt_comp=0 nortp_timeout=30 [audio_codec_0] mime=speex rate=32000 enabled=1 [audio_codec_1] mime=speex rate=16000 enabled=1 [audio_codec_2] mime=speex rate=8000 enabled=1 [audio_codec_3] mime=GSM rate=8000 enabled=1 [audio_codec_4] mime=PCMU rate=8000 enabled=1 [audio_codec_5] mime=PCMA rate=8000 enabled=1 [video_codec_0] mime=MP4V-ES rate=90000 enabled=1 recv_fmtp=profile-level-id=3 [video_codec_1] mime=theora rate=90000 enabled=1 [video_codec_2] mime=H263-1998 rate=90000 enabled=1 recv_fmtp=CIF=1;QCIF=1 [video_codec_3] mime=H263 rate=90000 enabled=1 [video_codec_4] mime=x-snow rate=90000 enabled=1 [auth_info_0] username=spyuser userid=spyuser passwd=secret realm="asterisk"
Be sure to use different alsa devices and different sip/rtp ports for additional spying clients.
For feedback (audio from the mixing desk sub out to the conference):
linphonec -c feedback.cfg -s 'feedback@pbx.sonologic.net'
Here is the config:
[sound] alsadev=feedback playback_dev_id=ALSA: feedback ringer_dev_id=ALSA: feedback capture_dev_id=ALSA: feedback remote_ring=/usr/share/sounds/linphone/ringback.wav [GtkUi] advanced_ui=1 [video] device=V4L2: /dev/video0 size=cif enabled=0 display=0 capture=0 show_local=0 self_view=0 [net] download_bw=0 upload_bw=0 firewall_policy=2 mtu=0 stun_server=p�� [sip] sip_port=5080 guess_hostname=1 inc_timeout=15 use_info=0 use_rfc2833=0 use_ipv6=0 register_only_when_network_is_up=1 default_proxy=-1 contact=<sip:spy@localhost:5070> [rtp] audio_rtp_port=7090 video_rtp_port=9078 audio_jitt_comp=60 video_jitt_comp=0 nortp_timeout=30 [audio_codec_0] mime=speex rate=32000 enabled=1 [audio_codec_1] mime=speex rate=16000 enabled=1 [audio_codec_2] mime=speex rate=8000 enabled=1 [audio_codec_3] mime=GSM rate=8000 enabled=1 [audio_codec_4] mime=PCMU rate=8000 enabled=1 [audio_codec_5] mime=PCMA rate=8000 enabled=1 [video_codec_0] mime=MP4V-ES rate=90000 enabled=1 recv_fmtp=profile-level-id=3 [video_codec_1] mime=theora rate=90000 enabled=1 [video_codec_2] mime=H263-1998 rate=90000 enabled=1 recv_fmtp=CIF=1;QCIF=1 [video_codec_3] mime=H263 rate=90000 enabled=1 [video_codec_4] mime=x-snow rate=90000 enabled=1 [auth_info_0] username=spy passwd=secret realm="asterisk"
extensions.ael
You need a sip.conf with a spy user and a feedback user, which both are in context spy.
You may want to create sip accounts for the panel members. Dump them in context panel.
You might want to make an extension 'panel' in your public sip context, which goes to panel|s|1.
// Copyright (c) 2011, Koen Martens <gmc@sonologic.nl>
context panel {
s => {
Answer(500);
BackGround(auth-incorrect);
WaitExten;
t => {
Hangup();
_XXXX => {
if (${DB_EXISTS(PANEL_ACCOUNT/${EXTEN})}) {
Set(participantno=${DB(PANEL_ACCOUNT/${EXTEN})});
jump s@panel_join;
} else {
Playback(auth-incorrect);
jump s;
h => {
NoOp(${DB_DELETE(PANEL_CHANNELS/${participantno})});
context panel_join {
s => {
// expects participantno to be set
if (${DB_EXISTS(PANEL_CHANNELS/${participantno})}) {
// Warn about participant already existing
Set(DB(PANEL_CHANNELS/${participantno})=${CHANNEL});
// ConfBridge(0,1q);
MeetMe(0,1q);
context spy {
_X => {
Answer(500);
while (1) {
if (${DB_EXISTS(PANEL_CHANNELS/${EXTEN})}) {
Set(channeltospy=${DB(PANEL_CHANNELS/${EXTEN})});
//ChanSpy(${channeltospy},oqXS);
ChanSpy(${channeltospy},oXSv(4));
Wait(5);
_feedback => {
Answer(500);
// ConfBridge(0,1qs);
MeetMe(0,1q);
echo => {
Answer(500);
Echo();
Hangup();
context moderator {
// Moderator for conference
1337 => {
Answer(2000);
// Warn about being joined as a moderator
// ConfBridge(0,1qsa);
MeetMe(0,1qsa);
// Dial out
_0X. => {
Set(outboundno=${EXTEN:1});
jump s@outboundtie;
context outboundtie {
s => {
Dial(SIP/moderator,60,T);
NoOp();
_X => {
Set(participantno=${EXTEN});
jump s@panel_join;
siptosis
Get the gateway software here.
Some useful documents:
- http://www.mhspot.com/sts/siptosis_config_issues.html
- http://www.mhspot.com/sts/siptosis_skype_trunk_howto.html
I am not pretending I know exactly what is going on here, but something like this should do the trick (supposing there is a sip account panel2 on your pbx):
# siptosis.cfg debug_level=3 # SipToSis configuration file # ___________________________________________ # #how opften in minutes to check for configuration changes (0=disable) configWatchInterval=0 #Set to log_debug.properties for full debugging logConfigFile=log.properties #Files containing Authorization rules siptoskypeauthfile=SipToSkypeAuth.props skypetosipauthfile=SkypeToSipAuth.props #Files containing dialing transforms SkypeOutDialingRulesFile=SkypeOutDialingRules.props SipOutDialingRulesFile=SipOutDialingRules.props #location of ua.jar file ua_jar=ua.jar #increase audio threads processing priority (0-2) 0=normal audioPriorityIncrease=0 #jitter enable and size (0=disable,1=small,2=medium,3=large,4=extra large) jitterLevel=2 #Set to skype_connect=no to disable connection to skype client - for testing purposes skype_connect=yes #Following ports are used by skype to transfer audio to/from siptosis # - use any unused ports - uses 2 ports per connection skype_audioportbase=64432 #Set to yes to enable skype DTMF support - uses more cpu enableSkypeDtmfDetector=no SkypeDtmfDetectorHitThreshold=90 SkypeDtmfDetectorSilenceThreshold=6 #Set to yes to regenerate SIP DTMF to Skype sendSipDtmfToSkype=yes #Set to yes to regenerate Skype DTMF to Sip sendSkypeDtmfToSip=yes #If using inband detectors, no to detect dtmf only during authentication (saves cpu) inbandFullTimeDtmfDetection=no #special mode if using skype client manually and an outbound skype call is made, it will attempt a sip call and link the two JoinManualSkypeOutboundCallToSip=no #refuse,voicemail,ignore,transferto:skypeid # If you are using a PBX with multiple clients/ids you probably want to use ignore # or possibly transferto:nextskypeid to the next skypeclient in the chain # then refuse on the last one SkypeInboundAllChannelsBusyAction=refuse #If an incoming skype call and sip destination is not available for any reason, what to do with skype call. #Allowed options: ring or refuse - ring allows the skype client to continue ringing and be answered manually. SkypeInboundSipDestUnavailableAction=refuse #busy,transferto:sipurl # If you want multiple outbound channels (AsteriskWin32 does not like this) # use transferto:sipurl to the next SipToSis channel in the chain then busy on the last one SipInboundAllChannelsBusyAction=busy #enable if skype client can support multiple active calls at same time - trying to lie here won't work #I have yet to find a client that can do this skypeclientsupportsmulticalls=no #For an ATA/SIP Phone set to 2 - this allows two total calls - one will be on hold. #For a PBX - depending on if the skype client supports multi calls - if not set it to 1 # otherwise set based on your hardware/bandwidth limitations concurrentcalllimit=2 #specify in 5 minute increments, 0=disable auto shutdown - siptosis will auto shutdown in x minutes when idle autoShutdownMinutes=0 #Seconds caller has to enter the pin number pintimeout=8 #Number of pin entry attempts before auto hangup pinretrylimit=3 #Seconds caller has to enter the destination number destinationtimeout=12 #Number of destination entry attempts before auto hangup destinationretrylimit=3 #SIP authorization system recordings - make your own if you like (wav 16k 16bit mono). pinFile=clips/enterPin.wav destinationFile=clips/enterDest.wav dialingFile=clips/dialing.wav invalidPinFile=clips/invalidPin.wav invalidDestFile=clips/invalidDest.wav #Skype authorization system recordings - make your own if you like (wav 16k 16bit mono). skypePinFile=clips/enterPin.wav skypeDestinationFile=clips/enterDest.wav skypeDialingFile=clips/dialing.wav skypeInvalidPinFile=clips/invalidPin.wav skypeInvalidDestFile=clips/invalidDest.wav #Used for Skypeout only - transmit skype feedback sound during PSTN call attempt handleEarlyMedia=yes #Send Skype IM when calling skype users - not used for skypeout sendSkypeIM=no skypeimmessage=You are about to receive a Skype Voice call from [callerid]. #delay between the IM and the actual skype call in seconds. sendSkypeImDelay=2 #transport_protocols=udp tcp transport_protocols=udp via_addr=10.1.3.20 host_ifaddr=ALL-INTERFACES enableNatTranslate=yes #outbound_proxy=127.0.0.2:5060 #Sample AUTO config with NO registration # username and password not important in this mode #Set to available port to transport SIP messages on siptosis computer #host_port=5070 #username=skypests #passwd=unimportantpassword # --- end of NO registration example --- #Sample config with NO registration - use if above auto config doesn't work - change 127.0.0.1 to ip address of computer running siptosis # username and password not important in this mode #Set to available port to transport SIP messages on siptosis computer #host_port=5070 #contact_url=sip:skypests@127.0.0.1:5070 #from_url="skypests" <sip:5611111111@127.0.0.1:5070> #username=skypests #passwd=unimportantpassword #realm=127.0.0.1 # --- end of NO registration example --- #Sample config WITH registration to GizmoProject - comment out NO registration info above first and uncomment the following #contact_url=sip:studiorevspace@127.0.0.1:5070 #from_url="panel2" <sip:panel2@pbx.sonologic.net:5060> #username=panel2 #passwd=secret #realm=asterisk #expires=120 #minregrenewtime=60 #regfailretrytime=15 #do_register=yes #outbound_proxy=pbx.sonologic.net:5060 # --- end of WITH registration example --- #sample FWD reg example - note the outbound proxy #host_port=5070 #contact_url=sip:8?????@SipToSisIpAddress:SipToSisHostPort #from_url="8?????" <sip:8?????@fwd.pulver.com:5060> #username=8????? #realm=fwd.pulver.com #passwd=???? #expires=240 #do_register=yes #minregrenewtime=120 #regfailretrytime=15 #outbound_proxy=fwdnat2.pulver.com:5060 # --- end of FWD registration example --- #sample pennytel reg example #host_port=5070 #contact_url=sip:8?????@SipToSisIpAddress:SipToSisHostPort #from_url="8?????" <sip:8?????@sip.pennytel.com:5060> #username=8????? #realm=sip.pennytel.com #passwd=123456 #expires=320 #do_register=yes #minregrenewtime=120 #regfailretrytime=15 # --- end of pennytel registration example --- #Sample Asterisk registration example - comment out NO registration info above first and uncomment the following. #host_port=5070 #contact_url=sip:skypetestuser@SipToSisIpAddress:SipToSisHostPort #from_url="skypetestuser" <sip:skypetestuser@asteriSkipAddress:asteriskHostPort> #username=skypetestuser #realm=asterisk #passwd=skypetest #expires=3600 #do_register=yes #minregrenewtime=120 #regfailretrytime=15 # --- end of Asterisk Reg example --- #Sample Asterisk registration example - comment out NO registration info above first and uncomment the following. host_port=5070 contact_url=sip:studiorevspace@10.1.3.20:5070 from_url="panel2" <sip:panel2@pbx.sonologic.net:5060> username=panel2 realm=asterisk passwd=geheim expires=3600 do_register=yes minregrenewtime=120 regfailretrytime=15 # --- end of Asterisk Reg example --- #Sample FreeSwitch regisration - can't use 5070 like others #host_port=5077 #contact_url=sip:skypetestuser@SipToSisIpAddress:SipToSisHostPort #from_url="skypetestuser" <sip:skypetestuser@freeswitchIPAddress:freeswitchHostPort> #username=skypetestuser #realm=freeswitchDeterminedRealm #passwd=skypetest #expires=3600 #do_register=yes #minregrenewtime=160 #regfailretrytime=15 # --- end of FreeSwitch Reg example --- #do_unregister=yes #do_unregister_all=yes #keepalive_time - set to zero to disable keep alives keepalive_time=45000 audio=yes #following is the SIP RTP port base - use an even port number audio_port=63200 #auto hangup after no rtp packets received for ? seconds noRtpReceivedAutoHangupSeconds=30 #only PCMU,PCMA,GSM (jmf lib),GSMTRI (tritonus libs) codecs currently supported - first one is the preferred codec #You can append RW to the codec name to disable sample averaging - use need to use filter with those. #Speex doesn't not work well at all - mass cpu usage audio_codec=PCMU,PCMA,GSMTRI,ILBC,SPEEX #PCMU/PCMA allow 160,240,320 - GSM allows 160 - ILBC allows 240, Speex allows 160, Speex16k allows 320 - need one size for each codec specified audio_frame_size=240,240,160,240,160 #if using dynamic payload types (speex and ilbc) you must specify the payload number (asterisk uses 98,97), if not you can remove this parameter audio_avp=-1,-1,-1,98,97 #Audio volume gains - 1 for each codec - (decimal number) 1=flat no gain, higher=louder, too high will clip or distort #volume sip->skype skype_audiooutgain=1,1,1,1,1 #volume skype->sip skype_audioingain=1.5,1.5,1.5,1.5,1.5 #Filter skype audio before being downsampled and sent to SIP device. #No Filtering FilterParams=NONE #RC lowpass filter #RC,delay time (lower lowers cutoff),RC constant (higher lowers cutoff) - 50,40 is a good starting point #FilterParams=RC,50,40 #FIR filter #FIR,Order (higher sharper cutoff and more cpu),window type (RECTANGULAR,HANNING,HAMMING,BLACKMAN),filter type (LP,HP,BP),minFreq,maxFreq #FilterParams=FIR,100,HANNING,LP,0,3200 #FilterParams=FIR,100,HANNING,HP,300,3200 #FilterParams=FIR,100,HANNING,BP,300,3200 #If yes, will send RTP packets to address received from the otherside # instead of what was received in the session descriptor. # This may help with one way audio problems. enableSendRTPtoReceivedAddress=yes #works with above setting - sending of rtpPackets can be redirected until receiving this number of packets. After that the address is locked. lockRtpSendAddressAfterPackets=1 #Set to -1 to disable rfc2833 some providers use 96 most use 101 dtmf2833payloadtype=101 #Use these for SIP INFO msg support - first is the most common type #dtmfinfotype=application/dtmf-relay #dtmfinfotype=application/dtmf #Use only if rfc2833 and INFO are not supported - uses more cpu enableSIPInbandDtmfDetector=no SipDtmfDetectorHitThreshold=30 SipDtmfDetectorSilenceThreshold=6 #params to control sip response address handling useViaRport=yes useViaReceived=yes #send all responses using outbound proxy - outbound proxy must be set up sendResponseUsingOutboundProxy=no #sip response for any uncovered reason baseFailureResponse=403 #sip response if remote skype user refused call skypeRefusedResponse=603 #sip response if skype call failed, invalid skype user, or no skype credit skypeFailedResponse=404 #sip response if skype returned unplaced status skypeUnPlacedResponse=408 #sip response if called party is busy skypeBusyResponse=600 #network buffers for skype api audio transport (0=leave at OS default) TcpRxBufferSize=8192 TcpTxBufferSize=8192 #network buffers for RTP audio transport (0=leave at OS default) RtpRxBufferSize=8192 RtpTxBufferSize=8192 #*** register server settings below *** not required if registration is not needed for phone #set to yes to turn on server registrar or no to disable is_registrar=yes #set to yes to allow register of users not already in registar database (users.db) register_new_users=yes #set to domains of server - see mjsip doc #domain_names=192.168.0.4 somedomain.com allowMultiContactsPerUser=no
And you will need something like this in your SkypeToSipAuth.props:
*,sip:panel@pbx.sonologic.net:5060
Somehow it seems to dial the sip uri without registering, so panel must be in the public incoming SIP context.
Known issues
- siptosis - spy output is very choppy, is this for all sip channels?? needs testing, spy works perfect when spying on iax channels
- killing siptoskype without hanging up the incoming skype call will result in odd lingering channels in asterisk, messing with your head
