RevRadio
| Project RevRadio | |
| Contact | User:Bertrik_Sikken |
| Last Update | 2013-08-11 |
HF (0 - 30 MHz)
To receive signals from the relatively low frequency "HF" band, we have a ham-it-up board. The ham-it-up converts signals from 0-30 MHz up to 125-155 MHz, this makes is possible to use an RTL2832-based dongle to receive them.
- morse and rtty beacons;
- amateur radio voice;
- amateur radio SSTV (slow-scan TV);
- number stations such as the buzzer;
- commercial AM broadcasts
- etc.
Generic VHF/UHF (30 - 1700 MHz)
For generic radio reception in the VHF/UHF bands, we have a setup consisting of a discone antenna (ICOM AH-7000) on the roof of RevSpace and an RTL2832 dongle (R820T tuner). A simple filter (1/4 wave open stub) has been built to suppress very strong pager signals.
- Citizens Band radio, 27 MHz
- 10 meter amateur band, 28-29.7 MHz
- 4 meter amateur band, 70-70.5 MHz
- broadcast FM stereo, 88-108 MHz;
- air traffic (voice);
- P2000 paging traffic at 169.650 MHz;
- weather images from the NOAA-15/18/19 weather satellites, at around 137 MHz;
- APRS traffic;
- weather info from weather balloons, at 400-410 MHz;
- ads-b/mode-s airplane transponders, at 1090 MHz
- etc.
HAB tracker (434-435 MHz)
For tracking high-altitude balloons, we have a setup consisting of a Diamond X-50N antenna on the roof of RevSpace, a so-called hab-amp (bandpass filter and 430-440 MHz LNA) and an RTL2832 dongle (FC0013 tuner). For more information, see the dedicated page at HAB_Tracker_Station
- high-altitude balloons, see spacenear tracker
Currently one PC is dedicated to radio reception, called "habtracker". To start the PC:
- Windows XP, hostname "habtracker", IP 10.42.44.94 (MAC 00:21:70:02:62:0f)
- Start the machine with a magic WoL packet: 'wakeonlan -i 10.42.255.255 00:21:70:02:62:0f; ping habtracker'
Remote control
The PC can be remotely controlled as follows:
- Teamviewer, ID: 675540724
- VNC: geheim ;-)
TODO
Stuff we are still planning to do:
- wait for proper cables for the ham-it-up
- think about an antenna for HF
