NoiseMeter
| Project NoiseMeter | |
| Bestand:NoiseMeter.jpg | |
| Measuring audio noise as citizen science | |
| Status | Initializing |
| Last Update | 2024-04-22 |
This project is about measuring environmental audio noise as citizen science.
For example, noise can be:
- road traffic noise (cars, mopeds, etc)
- air traffic noise,
- industrial noise, like building activities
Existing sound/noise meter projects:
- DNMS project by Helmut Bitter
- LoRa sound kit by Marcel Meek, ESP32 with I2S microphone, shares many concepts with EspAudioSensor
- LoRaWAN PM/Sound sensor by Bas van Drunen, shares many concepts with LoraWanDustSensor
- Amsterdam sounds kit from Waag Society,
- Unknown sensor tested by RIVM in Schiedam (mentioned on https://www.samenmetenaanluchtkwaliteit.nl/nieuws/citizen-science-geluidmetertest-op-rivm-terrein )
- Sound meter by Bart Jurgens uit Amerongen, link ???
This project page considers a kind of clone of the Amsterdam Sounds project.
Other interesting stuff:
- My brother looked inside three inexpensive sound meters: https://twitter.com/jrsikken/status/1779225176464392685
Nano33 IOT
Hardware is a nano33 iot board.
| SPH0645 | nano33 iot | Remark |
| SEL | - | leave unconnected |
| LRCK | A2 (16) - I2S FS | sample clock |
| DOUT | D4 (4) - I2S SD | data |
| BCLK | A3 (17) - I2S SCK | bit clock |
| GND | GND | |
| 3V | 3v3 |
The software is based on Arduino, a kind of clone of the Amsterdam Sounds project, modified to use WiFi (instead of LoRa), written by Rene Kuijf.
My modifications consist of a platformio configuration, for easy building.
See AdamSoundsInflux-slim-nano-33 github repo for the source code.
Casing
Microphone protection
To protect the microphone, use a membrane, like:
Junction box
Simple junction boxes sold by Gamma:
- https://www.gamma.nl/assortiment/attema-kabeldoos-m20-met-3-wartels-ip65/p/B410376 and
- https://www.gamma.nl/assortiment/attema-kabeldoos-ip65-3x-m25-m20/p/B306878 (IP65)
A downward pointing hole can be used for an 868 MHz LoRaWAN antenna.
Sensor.community casing
See https://sensor.community/docs/dnms/dnms-noise-measuring-dn40-result.jpg
Dimensions:
- microphone is on a half inch (12.7 mm OD) white polystyrene pipe, 115 mm long
- main piece is 25mm, length 160mm
- some other connecting piecess
"RIVM" test casing
Exact dimensions unknown, see photo on this page: https://samenmeten.nl/nieuws/citizen-science-geluidmetertest-op-rivm-terrein
My guess:
- microphone is on a 10mm diameter pipe, length 100mm
- main case is a 40mm diameter pipe, length 200mm
Experiments
Uni-T UT353 BT noise meter
This thing has bluetooth, however there is no functioning android app for it.
serial interface
There is an internal serial interface (9600 bps). When in bluetooth mode, but not connected yet, there is data going over this interface:
00000000 01 fc 12 aa bb 10 05 3b 20 20 34 31 2e 35 64 42 |.......; 41.5dB| 00000010 41 3d 34 00 04 15 01 fc 12 aa bb 10 05 3b 20 20 |A=4..........; | 00000020 34 30 2e 33 64 42 41 3d 34 00 04 12 01 fc 12 aa |40.3dBA=4.......| 00000030 bb 10 05 3b 20 20 33 39 2e 33 64 42 41 3d 34 00 |...; 39.3dBA=4.| 00000040 04 1a 01 fc 12 aa bb 10 05 3b 20 20 33 39 2e 30 |.........; 39.0| 00000050 64 42 41 3d 34 00 04 17 01 fc 12 aa bb 10 05 3b |dBA=4..........;| 00000060 20 20 33 39 2e 30 64 42 41 3d 34 00 04 17 01 fc | 39.0dBA=4.....| 00000070 12 aa bb 10 05 3b 20 20 33 38 2e 37 64 42 41 3d |.....; 38.7dBA=| 00000080 34 00 04 1d 01 fc 12 aa bb 10 05 3b 20 20 33 38 |4..........; 38| 00000090 2e 37 64 42 41 3d 34 00 04 1d 01 fc 12 aa bb 10 |.7dBA=4.........| 000000a0 05 3b 20 20 33 38 2e 33 64 42 41 3d 34 00 04 19 |.; 38.3dBA=4...| 000000b0 01 fc 12 aa bb 10 05 3b 20 20 33 38 2e 31 64 42 |.......; 38.1dB| 000000c0 41 3d 34 00 04 17 01 fc 12 aa bb 10 05 3b 20 20 |A=4..........; | 000000d0 33 37 2e 38 64 42 41 3d 34 00 04 1d 01 fc 12 aa |37.8dBA=4.......| 000000e0 bb 10 05 3b 20 20 33 38 2e 38 64 42 41 3d 34 00 |...; 38.8dBA=4.| 000000f0 04 1e 01 fc 12 aa bb 10 05 3b 20 20 33 38 2e 31 |.........; 38.1|
Dividing into "frames", starting with aa bb:
aa bb 10 05 3b 20 20 34 31 2e 35 64 42 41 3d 34 00 04 15 01 fc 12 "41.5dBA"
aa bb 10 05 3b 20 20 34 30 2e 33 64 42 41 3d 34 00 04 12 01 fc 12 "40.3dBA"
aa bb 10 05 3b 20 20 33 38 2e 38 64 42 41 3d 34 00 04 1e 01 fc 12 "38.8dBA"
header
<----------ASCII--------->
3d 34 ..
Each frame is 22 bytes long (0x16)
Bytes:
00: AA always? 01: BB always? 02: 10 03: 01, 05, ?? 04: ?? 05: 20 ascii 06: 20 ascii 07: xx ascii 08: xx ascii 09: xx ascii 0A: xx ascii 0B: xx ascii 0C: '=' 0D: '3' when in slow mode, '4' when is fast mode 0E: ?? 0F: ?? 10: ?? 11: ?? 12: ?? 13: ?? 14: ?? 15: 'h' when hold is pressed
BLE interface
This thing has a bluetooth interface. FCC report on the bluetooth part: https://fcc.report/FCC-ID/2AWEE-8762-01/4740558
In short, as I interpret the BLE configuration:
- a "Generic Attribute Profile" service, like all BLE devices have
- a service related to bluetooth parameters, also looks fairly standard, and not related to the measurements themselves
- a "Device information" service
- a custom vendor-specific service, where I suspect the noise-meter specific data is
In raw format:
- service 00001801-0000-1000-8000-00805f9b34fb: Generic Attribute Profile
- service: 0000ff12-0000-1000-8000-00805f9b34fb: Unknown
- characteristic: 0000ff01-0000-1000-8000-00805f9b34fb Unknown
- descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Data In"
- characteristic: 0000ff02-0000-1000-8000-00805f9b34fb Unknown
- descriptor: 00002902-0000-1000-8000-00805f9b34fb Client Characteristic Configuration
- descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Data Out"
- characteristic: 0000ff03-0000-1000-8000-00805f9b34fb Unknown
- descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Baud Rate"
- characteristic: 0000ff04-0000-1000-8000-00805f9b34fb Unknown
- descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Link Interval"
- characteristic: 0000ff05-0000-1000-8000-00805f9b34fb Unknown
- descriptor: 00002901-0000-1000-8000-00805f9b34fb Characteristic User Description "Pair code"
- characteristic: 0000ff06-0000-1000-8000-00805f9b34fb
- descriptor: 00002901-0000-1000-8000-00805f9b34fb "BT Name"
- characteristic: 0000ff07-0000-1000-8000-00805f9b34fb
- descriptor: 00002901-0000-1000-8000-00805f9b34fb "Pair Code En"
- characteristic: 0000ff08-0000-1000-8000-00805f9b34fb
- descriptor: 00002901-0000-1000-8000-00805f9b34fb "Adv interval"
- characteristic: 0000ff09-0000-1000-8000-00805f9b34fb
- descriptor: 00002901-0000-1000-8000-00805f9b34fb "TX Power"
- characteristic: 0000ff0a-0000-1000-8000-00805f9b34fb
- ... "MCU Delay"
- characteristic: 0000ff0b-0000-1000-8000-00805f9b34fb
- ... "Mode Control"
- characteristic: 0000fff0-0000-1000-8000-00805f9b34fb
- ... "Factory Set"
- characteristic: 0000fff1-0000-1000-8000-00805f9b34fb
- descriptor: 00002901-0000-1000-8000-00805f9b34fb "Reset"
- service: 0000180a-0000-1000-8000-00805f9b34fb Device Information
- service: 0000d0ff-3c17-d293-8e48-14fe2e4da212 Vendor specific
- characteristic: 0000ffd1-0000-1000-8000-00805f9b34fb Write
- characteristic: 0000ffd2-0000-1000-8000-00805f9b34fb Read, typically 40C1F6049BD7
- characteristic: 0000ffd3-0000-1000-8000-00805f9b34fb Read, typically 01901468
- characteristic: 0000ffd4-0000-1000-8000-00805f9b34fb Read, typically 21100048
- characteristic: 0000ffd5-0000-1000-8000-00805f9b34fb Read, typically ...?
- characteristic: 0000ffd8-0000-1000-8000-00805f9b34fb Write
- characteristic: 0000fff1-0000-1000-8000-00805f9b34fb Read, typically 0501000700080000F00F0000
- characteristic: 0000fff2-0000-1000-8000-00805f9b34fb Write
- characteristic: 0000ffe0-0000-1000-8000-00805f9b34fb Read, typically 00 00 00 01 01 00 00 00 01 90 14 68 21 10 00 48
