MainsFrequency2.0
Project MainsFrequency2.0 | |
A simple mains frequency counter | |
Contact | bertrik |
Last Update | 2023-03-27 |
Concept
Desired end result:
Algorithm for getting accurate instantaneous frequency out of it:
- Sample the mains frequency waveform during approximately one second (say 5 - 10 kHz)
- Determine the median, lower and upper quartiles of the waveform, and shift data so its values are symmetrically around zero
- Calculate zero crossings by doing linear regression to find the zero-crossing of the wave in the region around the zero crossing (in between the quartile values), this gives sub-sample time resolution
- The linear regression runs a kind of state machine, just keeping track of sum(x), sum(y), sum(x*x), sum(x*y) is enough to perform a linear regression at any time
- Do this over the approximately 50 cycles contained in the one second data and determine average frequency
Visualisation
Mains waveform ring
Concepts:
Calculation:
ZMPT101B | Wemos D1 mini | Remark |
GND | GND | Ground |
VCC | 5V | Powers the ZMPT101B from the wemos D1 mini |
OUT | A0 | Analog mains waveform, 0..5V, 180 kohm resistor in series |
To flash the esp8266:
- install platformio
- enter the esp8266sampler directory
cd esp8266sampler
- compile and upload
