!revbank
Met het bot-commando !revbank kun je je RevBank-saldo bekijken of opwaarderen via IRC in #revspace of een privebericht aan bar.
Authenticatie
De bot herkent je aan de hand van je cloak.
Saldo bekijken
!revbank
Saldo opwaarderen
  1. Check met !revbank of je wel herkend wordt, om vervelende verrassingen te voorkomen.
  2. Betaal via https://deposit.revspace.nl/ (zie ook deposit optie 1).
  3. Gebruik !revbank tr_xxxx waarbij tr_xxxx de code is die je na het betalen kreeg.
Implementatie
plantuml -p << 'END' > '!revbank.png' @startuml hide footbox mainframe IRC RevBank deposit using voucher code
participant irc_user box "bar (irc bot)" participant "!revbank" as script participant "!=auth" as auth end box participant revbank participant "deposit.revspace.nl\n/mollie.php" as backend participant "api.mollie.com" as mollie
irc_user -> script: !revbank tr_xxxx activate script script -> auth: irc cloak or hostname\nrevspace/participant/irc_user auth -> auth: find username
group#eee unknown irc cloak or hostname auth --> script: undefined script --> irc_user: error message note across: stop end
auth --> script: username script -> revbank: tr_xxxx username activate revbank revbank -> backend: tr_xxxx activate backend backend -> mollie: get payment mollie --> backend: payment backend -> backend: validate payment status
group#eee unknown, unpaid, or used voucher code backend --> revbank: error message revbank --> script: error message script --> irc_user: error message note across: stop end
backend -> mollie: update metadata:\nrevbank_status = pending backend --> revbank: amount deactivate backend revbank -> revbank: checkout revbank -> backend: finalize activate backend backend -> mollie: update metadata:\nrevbank_status = spent deactivate backend revbank --> script: new balance deactivate revbank script --> irc_user: new balance deactivate script
@enduml
END
