LoraWanDustSensor
| Last Update | 2021-12-15 |
What is it?
The concept consists of:
Features
- Supported particulate matter sensors (auto-detected):
- Uses LoRaWAN/TheThingsNetwork for communicating the measurement values:
- Hardware is based on off-the-shelf ESP32+LoRa hardware, specifically
- TTGO LoRa32 v1 and
- Heltec LoRa32 v2
- Works with TTNv3, the most recent version of TheThingsNetwork infrastructure
- Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-access-policy of TheThingsNetwork
- Data is encoded over LoRaWAN as Cayenne LPP, no custom payload decoder needed
- Supports WiFi over-the-air firmware upgrade
Similar nodes
- Apeldoorn-in-data
- (others...)
- Restructure firmware a bit to make the main .ino file smaller
- Auto-detect external display:
- if detected, use that and disable the internal display
- Show comprehensive information on startup screen, consider making this one of the main 'views' (device info, measurements, QR code)
- board type (TTGO v1 or Heltec v2), relevant to firmware update
- type of PM sensor: SDS011 or SPS30
- type of RH sensor: BME280 or absent
Ideas:
- Make measurement values available through bluetooth
QR code for TheThingsNetwork credentials
- QR contents will be:
- Example content should fit in 29x29 pixel version 3 QR code (format "LW:JoinEUI:DevEUI:AppKey" as hexadecimal)
LW:1122334455667788:1122334455667788:112233445566778899AABBCCDDEEFF00
The node is based on Arduino-compatible ESP32 boards with LoRaWAN:
- TTGO ESP32 board ("ttgo-lora32-v1") or the
- The humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
| GPIO15 | GPIO15 | BME280 SCL | Piggybacking on the I2C bus to the display |
| GPIO4 | GPIO4 | BME280 SDA | Piggybacking on the I2C bus to the display |
For reference:
Display
The display on the ESP32 LoRa boards is an 128x64 pixel OLED display. It wears out after some months, pixels that have been one more than other pixels will become dimmer.
Hackaday article about this effect. The burn-in/dimming effect is very obvious here.
Firmware
- install platformio:
- get the source from github:
cd LoraWanPmSensor cd Esp32PmSensor
pio run -e ttgov1 -t upload
pio run -e heltecv2 -t upload
Firmware update
Once the initial firmware has been loaded into the device, further firmware updates can be done over WiFi:
- Select the appropriate BIN file, the will be updated and reboot
Payload encoding
Cayenne
Optionally:
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
In terms of interval:
Downlink commands
I plan the following downlink commands:
Principles:
