EspAudioSensor
| ESP32-based audio sensor | |
| Last Update | 2021-09-26 |
Links back:
- https://iotassistant.io/esp32/smart-door-bell-noise-meter-using-fft-esp32/
- https://en.usini.eu/digital_microphone_on_esp32/
Ideas
- Bluetooth interface. The ESP32 supports bluetooth as an RF technology. It would be nice to be able to quickly see the current/most recently measured data. Perhaps this can be done with the bluetooth 'noise' characteristic.
- See GATT_Specification_Supplement_v5.pdf paragraph 3.151, it has a noise characteristic with 1 dB resolution.
- 0x27C3 is the GATT unit for sound pressure, see https://btprodspecificationrefs.blob.core.windows.net/assigned-values/16-bit%20UUID%20Numbers%20Document.pdf
- 0x181A is the GATT environmental sensing service apparently
- 0x2A6E/F is temperature/humidity apparently, specified in https://btprodspecificationrefs.blob.core.windows.net/assigned-values/16-bit%20UUID%20Numbers%20Document.pdf
The concept is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server forwards the measurements to sensor.community, from there they are automatically picked up by RIVM
- how often should audio be sampled? 1 second/minute? 10 seconds/min? How long should the audio fragment be?
Theory
A weighting
| Octave start | Octave center | Octave end | Remark |
| 88 Hz | 125 Hz | 177 Hz | |
| 44 Hz | 63 Hz | 88 Hz | |
| 22 Hz | 31 Hz | 44 Hz |
FFT
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
NodeMCU ESP32
My initial prototype uses an NodeMCU ESP32.
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
Heltec LoRa32 v2
What the software should do:
- Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
- Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
- Every 5 minutes, send the statistics to the network using WiFi or LoRa
Backend code for processing and forwarding the data from the sensor of Marcel Meek can be found at https://github.com/bertrik/noiseforwarder.
DNMS
- it needs a custom PCB
DNMS Protocol:
- 1 DNMS_CMD_RESET
- 2 DNMS_CMD_READ_VERSION
- 3 DNMS_CMD_CALCULATE_LEQ
- 4 DNMS_CMD_READ_DATA_READY
- 5 DNMS_CMD_READ_LEQ
- a command looks like this:
Sensor.community protocol
- REST with JSON
Links:
