EspAudioSensor
Project ESP audio sensor | |
ESP32-based audio sensor | |
Contact | bertrik |
Last Update | 2021-09-26 |
Links back:
- https://iotassistant.io/esp32/smart-door-bell-noise-meter-using-fft-esp32/
- https://en.usini.eu/digital_microphone_on_esp32/
Ideas
- It would be nice to be able to quickly see the current/most recently measured data. Perhaps this can be done with the bluetooth 'noise' characteristic. See GATT_Specification_Supplement_v5.pdf paragraph 3.151, it has a noise characteristic with 1 dB resolution.
The concept is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server forwards the measurements to sensor.community, from there they are automatically picked up by RIVM
- how often should audio be sampled? 1 second/minute? 10 seconds/min? How long should the audio fragment be?
Theory
A weighting
Octave start | Octave center | Octave end | Remark |
- | - | 22627 Hz | sample rate |
5657 Hz | 8000 Hz | 11314 Hz | |
2828 Hz | 4000 Hz | 5657 Hz | |
1414 Hz | 2000 Hz | 2828 Hz | |
707 Hz | 1000 Hz | 1414 Hz | |
354 Hz | 500 Hz | 707 Hz | |
177 Hz | 250 Hz | 354 Hz | |
88 Hz | 125 Hz | 177 Hz | |
44 Hz | 63 Hz | 88 Hz | |
22 Hz | 31 Hz | 44 Hz |
FFT
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
NodeMCU ESP32
My initial prototype uses an NodeMCU ESP32.
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
Heltec LoRa32 v2
What the software should do:
- Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
- Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
- Every 5 minutes, send the statistics to the network using WiFi or LoRa
Backend code for processing and forwarding the data from the sensor of Marcel Meek can be found at https://github.com/bertrik/noiseforwarder.
DNMS
- it needs a custom PCB
DNMS Protocol:
- 1 DNMS_CMD_RESET
- 2 DNMS_CMD_READ_VERSION
- 3 DNMS_CMD_CALCULATE_LEQ
- 4 DNMS_CMD_READ_DATA_READY
- 5 DNMS_CMD_READ_LEQ
- a command looks like this:
Sensor.community protocol
- REST with JSON
Links:
