LoraWanDustSensor
Project LoRaWAN dust Sensor | |
LoRaWAN airborne particulate matter sensor | |
Contact | bertrik |
Last Update | 2021-07-26 |
What is it?
The concept consists of:
Features
- LoRaWAN-enabled particulate matter sensor node, based on off-the-shelf ESP32+LoRa hardware, specifically the TTGO LoRa32 v1 and Heltec LoRa32 v2 board.
- Works with the most recent version (v3) of TheThingsNetwork infrastructure
- Data upload interval defaults to 5 minutes (SF7), scales with spreading-factor to satisfy the fair-use-policy of TheThingsNetwork
- Data is encoded as Cayenne LPP, no custom payload decoder needed
- Supported sensors (auto-detected):
- Firmware can be upgraded over-the-air (WiFi)
Similar nodes
- Apeldoorn-in-data
- (others...)
- Base send interval on the exact time spent sending data, investigate if the LoRaWAN device stack supports this
-> not currently explicitly supported
- Improve firmware update:
- Show current software version in the welcome screen
- Show hardware model (TTGO or Heltec) in the welcome screen
- Show QR code on startup containing DevEUI, AppEUI and AppKey, for easier commissioning
- AppEUI could be fixed
- AppKey could be randomly generated (and stored in EEPROM), much more secure than a fixed key
- Example content should fit in 33x33 QR code:
D:1122334455667788 A:1122334455667788 K:112233445566778899AABBCCDDEEFF00
The node is based on Arduino-compatible ESP32 boards with LoRaWAN:
- TTGO ESP32 board ("ttgo-lora32-v1") or the
- The humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
TTGO LoRa v1 | Heltec LoRa v2 | Sensor | Remark |
5V | 5V | 5V (SDS pin 3) | SPS30 5v (red), triple-check this, swapping 5V/GND destroys the SDS011 |
GND | GND | GND (SDS pin 5) | SPS30 gnd (black), triple-check this, swapping 5V/GND destroys the SDS011 |
GPIO23 | GPIO23 | RXD (SDS pin 6) | SPS30 RX (white?) |
GPIO22 | GPIO22 | TXD (SDS pin 7) | SPS30 TX (purple?) |
3.3V | 3.3V/Vext | BME280 3V | Both Vext and 3.3V can be used |
GND | GND | BME280 GND | ground |
GPIO15 | GPIO15 | BME280 SCL | |
GPIO4 | GPIO4 | BME280 SDA |
For reference:
Firmware
- install platformio:
- get the source from github:
cd LoraWanPmSensor cd Esp32PmSensor
pio run -e ttgov1 -t upload
pio run -e heltecv2 -t upload
Firmware update
Once the initial firmware has been loaded into the device, further firmware updates can be done over WiFi:
- Select the appropriate BIN file, the will be updated and reboot
Payload encoding
Cayenne
Optionally:
Example:
Binary
- 1 byte : 0x04
- 2 bytes: PM25(?) big endian
- 2 bytes: PM10(?) big endian
- RIVM node, sends 20 bytes
- 2 bytes pressure (unit?)
- 2 bytes pm10 (unit?)
- 2 bytes pm25 (unit?)
- 2 bytes op1 (unit?)
- 2 bytes op2 (unit?)
- 4 bytes latitude (unit?)
- 4 bytes longitude (unit?)
LoraWan time budget
Consider the following:
In terms of interval:
Downlink commands
I plan the following downlink commands:
Principles:
