LoraWanDustSensor
Project LoRaWAN dust Sensor
Last Update 2021-03-22
What is it?
The concept consists of:
  • a sensor that measures airborne particulate matter and sends the measurement data using LoRaWAN to TheThingsNetwork (TTN)
  • a forwarder application that collects the data from TTN and forwards it to sensor.community (formerly luftdaten), opensensemap, mycayenne dashboard, etc.
This has been done before by other people, but it appears there is no universal solution. I am publishing all source code on github and will put up documentation on this wiki. My concept uses Cayenne because it is the closest practical thing towards a universal format but still reasonably compact format.
The OTAA key can be programmed and stored in the node (initially it has a working default key), the session keys exist only as long as the device is powered. Each node identifies itself by a DeviceEUI based on the built-in unique ESP32 serial number.
  • each node can be flashed with the same firmware
  • the node shows its unique Device EUI on the OLED
  • at the TTN console, you register the node with the unique Device EUI
  • the sensor node receives encryption keys over the air automatically by OTAA
  • migration from the v2 stack to the v3 stack of the TTN infrastructure is almost effortless on the node side (just a reboot)
  • Firmware update over WiFi:
    • basic OTA-over-WiFi has been implemented, allows remote flashing from the development environment, not so user-friendly, not secure
    • use a WiFi password for the ESP32 over-the-air firmware update, add a default password, make the password configurable over the serial interface
  • Implement a simple command set through LoRaWAN downlink commands, for example:
    • a command to trigger an immediate reboot of the node
  • Implement the ESP-Now lamp/display protocol, for easy visualisation, see https://revspace.nl/StofAnanas#Next_generation.
    • Start with sending the particulate matter measurements
    • Add a suggested colour indication later
  • Start the LoRaWAN OTAA procedure at a slower rate than SF7, so it doesn't take a long time before the node finally connects to the network if it's not close to a gateway -> tried this, didn't work, ADR algorithm of TTN is a black box ...
The node is based on the Arduino framework:
  • for the processor board, either the TTGO ESP32 board ("ttgo-lora32-v1") or the Heltec LoRa32 V2 can be used.
  • the particulate matter sensor is the SDS011, just like in the sensor.community project.
  • the humidity/temperature sensor is the BME280 (superior to the DHT11/22).
Pinout
TTGO LoRa v1 Heltec LoRa v2 Sensor Remark
5V 5V SDS011 5V (pin 3) triple-check this, swapping 5V/GND destroys the SDS011
GND GND SDS011 GND (pin 5) triple-check this, swapping 5V/GND destroys the SDS011
GPIO23 GPIO23 SDS011 RXD (pin 6)
GPIO22 GPIO22 SDS011 TXD (pin 7)
3.3V 3.3V/Vext BME280 3V Both Vext and 3.3V can be used
GND GND BME280 GND ground
GPIO15 GPIO15 BME280 SCL
GPIO4 GPIO4 BME280 SDA
For reference:
  • install platformio:
 sudo apt install python3-pip
 sudo pip3 install platformio
 pio update
  • get the source from github:
  • enter the correct directory:
 cd LoraWanPmSensor
 cd Esp32PmSensor
  • compile and upload (for TTGO LoRa32 v1 board):
 pio run -e ttgov1 -t upload
 pio run -e heltecv2 -t upload
On Windows, with the Arduino IDE
  • Install the Arduino IDE ...
  • Get the ESP32 support package ...
  • Install the following libraries
    • squix78/ESP8266_SSD1306
    • mcci-catena/MCCI LoRaWAN LMIC library, version 3.3.0
    • sparkfun/SparkFun BME280
  • Set the target to either the TTGO LoRa32 v1 or Heltec LoRa32 v2
  • Ctrl-U to compile and upload
Payload encoding
My firmware uses the Cayenne LPP (low power payload) encoding.
Cayenne
  • 4 bytes: PM10: analog input (type 2), channel id 1, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: PM2.5: analog input (type 2), channel id 2, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Temperature: temperature (type 103), with value in units of 0.1 degrees celcius
  • 3 bytes: Humidity: humidity (type 104), with value in units of 0.5 %
Optionally:
  • 4 bytes: PM1.0: analog input (type 2), channel id 0, with value in units of 0.01 ug/m3, saturated to 327.67 ug/m3
  • 4 bytes: Pressure: barometer (type 115), with value in units of 0.1 mbar, or 10 Pa (optional)
Example:
Binary
LoraWan time budget
Consider the following:
  • radio regulations generally have a 1% duty cycle requirement for the two bands used by the 8 LoRaWAN (EU) frequencies, so according to the legal limits, there is about (86400s x 1% x 2bands) = 1728 seconds per day send time at the best case.
  • TheThingsNetwork has a FUP of 30s of data upload per day. This is actually a *lot* more strict than allowed purely by radio regulations.
  • The sensor.community backend runs on a 5 minute interval, or 288 measurements per day.
  • The default sensor.community WiFi firmware sends new data every 145s by default
In terms of interval:
  • SF7: payload 17 bytes -> 71.9 ms/transmission -> every 3m27s
  • SF8: payload 17 bytes -> 123,4 ms/transmission -> every 5m55s
  • SF9: payload 17 bytes -> 226,3 ms/transmission -> every 10m32s
  • SF10: payload 17 bytes -> 452.6 ms/transmission -> every 21m43s
  • smallest possible binary payload is 4 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 51.5 ms, SF8 takes 92.7 ms, SF9 takes 164.9 ms
  • smallest Cayenne payload is 8 bytes (PM10 and PM2.5, no temperature, no humidity): SF7 takes 56.6 ms, SF8 takes 102.9 ms, SF9 takes 185.3 ms
Node design
The luftdaten backend has a 5 minute "heartbeat", so at least one measurement per 5 minutes should be sent to avoid disappearing from the map. The node firmware (attempts to) send a message every 4m30s seconds, just like the luftdaten WiFi sensor. A little bit of randomness (30 s) is added to avoid nodes transmitting at exactly the same time over long periods of time and interfering with each other.
  • INIT: determine presence of the SDS011, print the SDS011 serial number
  • IDLE: wait until the start of the cycle, then turn on the fan
  • WARMUP: wait 20 seconds while the sensor "warms up"
  • MEASURE: measure 10 seconds, then turn off fan, calculate median/average and send LoRaWAN message
Building with platformio
 pio update
To compile and upload:
TTN key provisioning
To keep things simple, there is no key provisioning for the nodes themselves. All nodes use the same firmware with the same APP EUI and the same APP KEY. The thing that makes each node unique is its DEVEUI, this is derived from the built-in unique ESP32 id.
On the TTN side, each node will have to be registered by its DEV EUI. The following scheme is used to make TTN provisioning as simple as possible:
  • Each node can be programmed with the *same* software, no source code modification is required
  • The node administrator needs to enter the following properties at the TTN console, for each node:
    • The Device EUI is derived from the node-specific ESP32 MAC address, the node shows this on its OLED
    • The App EUI has a fixed value and is the same for all nodes
    • The App Key has a fixed value and is the same for all nodes
    • Use 32-bit frame counter, leave frame counter checks enabled
The node uses a fixed App EUI and App key by default, but each node can also be configured to use a custom set of OTAA keys.
Backend
This is implemented by my LoraLuftdatenForwarder (source code).
  • Subscribes to a TTN MQTT stream and receives incoming messages, both TTN "v2" and "v3" stacks are supported.
  • Decodes Cayenne and custom payloads.
  • Forwards to sensor.community (formerly luftdaten.info)
  • Forwards to opensensemap.org, the opensensebox id is automatically picked up from an attribute specified in the TTN v3 console.
  • Forward to feinstaub app (experimental), https://pm.mrgames-server.de/
Development
To receive data using mosquitto, separately from the backend:
Example upstream data:
Example downstream data:
Gateway API:
Useful tools:
