EspAudioSensor
Project ESP audio sensor
ESP32-based audio sensor
Last Update 2019-05-02
The plan is to do this by combining an inexpensive WiFi-enabled ESP-32 microcontroller with a standard I2S digital microphone. The ESP-32 performs a frequency analysis and is able to forward the measurement to a server.
Further development:
  • It seems to work so far! Let's test it, e.g. by running it all day and plotting the noise values.
  • Apply A-weighting locally to get a direct idea of the loudness
  • Add client code for uploading data somewhere, perhaps just start with sending MQTT into influx, so we can plot things using grafana
Another idea:
  • implement basic speech recognition of fixed phrases, like "ok google", "hey siri", AKA "wake words"
The idea is the following:
  • A small box containing a microphone outside your house measures environmental sounds (traffic, etc), for example it takes a 1 second audio recording every 10 seconds
  • A spectral analysis is made of the audio (separating it in different frequency bands), calculating sound intensity for each individual band
  • Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
  • The central server takes the measured intensities and can do corrections, like a microphone specific correction, or a correction to apply A-weighting
  • The central server visualises the measurements:
    • We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
    • We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. We can then easily apply sensor/housing specific corrections, do A weighting, etc.
A weighting
Subjective audio levels are generally calculated on a logarithmic scale in dB using "A-weighting". A-weighting calculates a subjective loudness level from a physical loudness, applying a correction factor for each band.
Octave start Octave center Octave end Remark
- - 22627 Hz sample rate
5657 Hz 8000 Hz 11314 Hz
2828 Hz 4000 Hz 5657 Hz
1414 Hz 2000 Hz 2828 Hz
707 Hz 1000 Hz 1414 Hz
354 Hz 500 Hz 707 Hz
177 Hz 250 Hz 354 Hz
88 Hz 125 Hz 177 Hz
44 Hz 63 Hz 88 Hz
22 Hz 31 Hz 44 Hz
FFT
  • arduinoFFT looks nice, but .. it does all calculations in double, severely limiting the audio buffer size. For each sample, you need two doubles, so that's 16 bytes per sample. I can use about 6000 samples in the audio buffer. Using floats would give me twice the audio buffer size. I could just copy the files and modify them for double->float (and fix any other compiler warnings).
  • Alternatively, esp32-fft looks nice, it uses floats instead of doubles and is optimised for esp32, but it uses malloc internally ... Also I can't use it as an Arduino library because it doesn't have the arduino library structure (with a src dir, examples dir, library.json file, library.properties file, etc) Maybe I can still use it by copying it in my sketch.
Links:
Decibel meters
Fairly typical specs:
  • dynamic range: 30 - 130 dB
  • accuracy: 1.5-2 dB
  • frequency range: 31.5 Hz - 8 kHz (!)
  • norm: EN 61672-1
  • an ESP32 (or possibly an ESP8266), it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet
  • a digital I2S microphone, like the INMP441 (datasheet)
The microphone is connected to the microcontroller as follows:
  • INMP441 GND to ESP32 GND
  • INMP441 VDD to ESP32 3.3V
  • INMP441 SD to ESP32 A4/32
  • INMP441 SCK to ESP32 A16/14
  • INMP441 WS to ESP32 15
  • INMP441 L/R to ESP32 GND
What the software should do:
  • Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
  • On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
  • Calculate power for each FFT-bin (Im-squared + Re-squared) and sum up bins per octave.
  • Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
  • Every 5 minutes, send the statistics to the network using WiFi or LoRa
