EspAudioSensor
| ESP-based audio sensor | |
| Last Update | 2019-04-29 |
The plan is to do this by combining an inexpensive WiFi-enabled ESP-32 microcontroller with a standard I2S digital microphone.
Further development:
- Use the arduinoFFT library, but replace all doubles with floats -> it can fit about 14000 samples in that case. Commercial sound meters only go up to the 8000 Hz band, which ends at 11313 Hz -> should be doable.
- improve the arduinoFFT library by removing all deprecated methods
Another idea:
- implement basic speech recognition of fixed phrases, like "ok google", "hey siri"
The idea is the following:
- Every 5 minutes, the measured sound intensity is sent to a central server on the internet using your home WiFi connection. Because we only communicate intensities, this does not reveal audio fragments (conversations for example).
- The central server visualises the measurements:
- We can plot the sound intensities on a map as a coloured dot and get a nice overview how the map changes during the day/week/year
- We can plot the sound intensities of individual nodes vs time, and get an idea how sound varies from day/night/week/year
Theory
The plan is to divide the audio spectrum up into octaves and calculate the total energy in each octave. We can then easily apply sensor/housing specific corrections, do A weighting, etc.
Subjective audio levels are generally calculated on a logarithmic scale in dB using "A-weighting". A-weighting calculates a subjective loudness level from a physical loudness, applying a correction factor for each band. The division of the audio spectrum is chosen so it matches the octaves used in the A-weighting, see https://en.wikipedia.org/wiki/Octave_band#Octave_Bands
FFT
The energy in each octave is calculated by applying an FFT (fast fourier transform) on the audio data. The FFT takes in real values and outputs complex values. The intensity in each octave band is by summing the energy in a set of FFT 'bins'. The energy in each bin is calculated as the real part squared plus the imaginary part squared. I plan to use the 'flat-top' window because it has good properties for measuring power levels.
- arduinoFFT looks nice, but .. it does all calculations in double, severely limiting the audio buffer size. For each sample, you need two doubles, so that's 16 bytes per sample. I can use about 6000 samples in the audio buffer. Using floats would give me twice the audio buffer size and doubles are probably not super fast, see
Links:
Decibel meters
Fairly typical specs:
- dynamic range: 30 - 130 dB
- accuracy: 1.5-2 dB
- norm: EN 61672-1
- an ESP32 (or possibly an ESP8266), it has an I2S digital audio input for sampling data from a digital microphone and a WiFi interface to communicate things to the internet
The microphone is connected to the microcontroller as follows:
- INMP441 GND to ESP32 GND
- INMP441 VDD to ESP32 3.3V
- INMP441 SD to ESP32 A4/32
- INMP441 SCK to ESP32 A16/14
- INMP441 WS to ESP32 15
- INMP441 L/R to ESP32 GND
What the software should do:
- Take an audio measurement from the microphone at a regular interval (say 1 second every 10 seconds)
- On the recorded audio, perform a 4096-point real->complex FFT with a windowing function (flat-top for example).
- Calculate statistics, e.g. minimum/average/maximum over a 5 minute interval and convert to a logarithmic scale (decibels)
- Every 5 minutes, send the statistics to the network using WiFi or LoRa
To investigate:
- https://github.com/maspetsberger/esp32-i2s-mems
- A library that performs FFT on ESP32 is arduinoFFT.
- I plan to use the flat-top window
