EspNowSkip
Revision as of 20:15, 7 July 2018 by Bertrik Sikken (talk | contribs) (Status update)
Project EspNowSkip
Music skip button based on ESP-Now protocol
Contact bertrik, jelly
Last Update 2018-07-07
  • you want it to react reasonably quickly, with little latency between pressing the button and skipping to the next song
  • the skip button should be mobile, so it is battery powered and has to be conservative with current
  • we used to have a wireless infrastructure based on NRF24L01+ modules, this was never really reliable and it got more complicated with incompatible fakes appearing on the market
  • we have a WiFi-based skip button, but it's online continuously, drawing way too much power to make it mobile (so it's tethered to a 5V charger)
The current ESP-Now skip button prototype needs only about 200 ms after wakeup to send a message and return to deep sleep again.
schematic
The proposed way of wiring it up, is to make the actual physical button just power up the board. A (super-)cap parallel over the supply wires makes it possible to run the skip program to completion from just a single short press. In case a ESP-Now re-initialisation (which takes a bit more time) is needed, you can just keep the button pressed for a bit longer to complete the initialization process. This way, the SKIP program starts executing as soon as you press the button and there is no quiescent current drain on the battery.
The receiver/master is connected to a raspberry pi or similar, with the EspNowSkip receiving packets from the air and sending them over serial to the raspberry pi. The raspberry pi can then do its magic to make the music skip (e.g. GET/PUT a specific URL of the playback software, send an MQTT message, etc.)
Capacitor calculation
 C = I . dT / dV
Battery life
Source code
It contains the following programs:
  • skipbutton.ino: an Arduino program that is the button part of the system (slave) which sends the skip message
  • skipreceiver.ino: an Arduino program that is the central part of the system (master) which receives the skip message
  • skipforwarder.ino: an Arduino program that accepts a skip message over serial from another ESP and forwards it to the squeeze-player and MQTT
  • forwardskip.py: a Python script that takes a topic/payload over the serial port from a skipreceiver and forwards it to MQTT
EspNowSkip protocol
It works like this:
  • there are two roles:
    • a single central "master" node
    • one or more "slave" skip-buttons
  • when the skip button is pressed, the ESP8266 resets and starts running, reads the last known ESP-Now channel and MAC address from EEPROM and sends the "SKIP" message
    • if the skip button doesn't receive an ACK from the central node, it starts a kind of discovery to re-establish the channel and MAC address of the central node
  • the central node is configured as an AP with a specific name (e.g. "espnow-revspace")
  • the discovery procedure tries to find the central node by doing an AP scan, the AP name is the only thing that needs to be agreed upon in advance between master and slave code
    • in the list of the APs, the slave node finds the SSID belonging to the central node, then it also knows the wifi channel and MAC address of the central node
    • the slave node stores both wifi channel and MAC address in (emulated) EEPROM and goes back to sleep
The data we send is an MQTT-like topic + message, for example
 revspace/button/skip now
The master node can simply parse this into two parts (split on the first space) and bridge this to the Revspace MQTT infrastructure.
Skip protocol
Classic HTTP GET
where
 p0 is "playlist"
 p1 is "jump"
 p2 is "%2B1", or "+1" escaped
 player is "d8%3Ad3%3A85%3A17%3A30%3A9c", or "d8:d3:85:17:30:9c" escaped, which is the unique id of the particular player instance
Example:
JSON Protocol
To skip, send a HTTP POST to:
 http://jukebox.space.revspace.nl:9000/jsonrpc.js
with content
Expect a result like:
References
Future
Done:
  • make sure ESP8266 ESP-now implementation is interoperable with ESP32 ESP-now implementation indeed it is!
  • put it in a nice case (ceiling cavia watches you skip)
More distant future:
  • add a supercap to the skip button, to allow a short press (e.g. 100 ms) to also be registered -> I have various types in my Samla (e.g. 0.1F 5.5V).
  • use ESP-Now also for other kinds of hacker space infrastructure where low-power consumption is important and/or a power wire is inconvenient: outside temperature for example.
  • add more buttons besides just skipping.
  • send data back to the skip button, for example we could send a "now playing" message or album art back to a SHA2017 badge and have it shown on its e-ink display.
  • use encryption/authentication on the ESP-Now link. I think the protocol already allows this, using a simple shared secret.
