Door sign
Revision as of 22:14, 5 July 2018 by Juerd (talk | contribs)
Project Door sign
Contact User:Gori, User:Thomas
Last Update 2018-07-05
Make a cooler revspace sign for about the door
Finished product
Specs
Sign must
  • be 600x400 mm or enough to cover the ugly patch above the door
  • be securely fastened and removeable
  • leave no significant marks on the building
  • be awesome
Technical design
  • 2mm 304 stainless steel plate, 2B finish
  • 2 10x40x2 strips, riveted to the building, with 2x 3mm rvs screws , holing the plate to the building
  • Use Vinyl sticker as resist, also sticker the back and edges
  • Etch for 2 to 3 hours with 40% FeCl3, in a washing machine leak tray
  • Watch out, if vinyl is cut well in advanced, likelihood of edges getting loose increases. This creates uneven edges when etching. Cut right before application!
graphic design
  • Logo
  • Letters area polished with rvs polishing paste and buffing wheel
  • LED area heat treated with RVS wire wheel to get a brushed surface, then heat treated to golder colour
  • rest etched
