Pov
what is it
POV is the (virtual) server managing the webcams. It stores video files of all webcams over the last 2 days.
OS specifications
- debian stretch
- 32b
- virtual machine with 2 cores
- 1GB ram
- 10GB root filesystem
- 100GB storage for camera files
software
- motion https://motion-project.github.io/
- used for camera 6 and 11 which are down
- constatus https://vanheusden.com/constatus/
- all other cameras
motion
- motion is installed from the debian repository
- configuration files are under /etc/motion
- main configuration is motion.conf which includes cam*.conf
- as by the design of motion, all its cameras (6 + 11) are monitored from 1 process
constatus
- installed from the github repository https://github.com/flok99/constatus
- installed under /usr/local/constatus
- started (currently, 20170903) from /etc/rc.local
- each camera has its own constatus process - the idea is that if something crashes, that not all cameras will go down
- video archive can be viewed under http://10.42.19.84:port/ where port is 8101 for camera 1, 8102 for camera 2 and so on
The configuration files are JSON files. They consist of 2 or more sections: general, source and then optional sections. Every other section (apart from video loopback) have an array of entries for their data. E.g.
Recording Specifications
- 5 FPS video files
- 2 FPS HTTP web interface
Cameras
Number | Port | Physical device protocol | Where |
CAM 1 | 8084 | RTSP | hanging above the 3D printer |
CAM 2 | 8085 | MJPEG | cantina/kitchen |
CAM 3 | 8086 | MJPEG | back side of klusruimte |
CAM 4 | 8087 | MJPEG | front side of klusruimte |
CAM 5 | 8088 | RTSP | houtbewerkingsruimte (woodworking shop) |
CAM 6 | broken | ||
CAM 7 | 8090 | MJPEG, source is Verint Nextiva | these produce an RTP stream which are converted to MJPEG by scripting running on the shell server, see https://github.com/Peetz0r/revcaminfra. |
CAM 8 | 8091 | ||
CAM 9 | 8092 | ||
CAM 10 | 8093 | ||
CAM 11 | This one goes up to eleven?! (this camera doesn't actually exist yet) |
