ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone | |
My clone of the Sinclair ZX81 | |
Contact | Mahjongg |
Last Update | 2016-04-03 |
As for now comments and questions on the design can be made here [3] (raspberry PI forum off topic section) :-)
Introduction to the ZX81+35
3D Preview of early ZX81+34
Schematic 81+34
The old (version 1) schematic of revision 2.0 (.PDF) can be found here: File:ZX81+34 schema.pdf
There is also a color coded schematic (.PDF), it can be found here: File:ZX81+34 kleur REV 2.0.pdf.
The Bill of Material (BOM) for the original ZX81+34 can be found here File:Z81+34 BOM.ods
Layout ZX81+34
Keyboard for ZX81+34/35
A version that supports the ZXPand can be downloaded here: File:New ZX81+34 keyboard ZXPand version.pdf
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
File:ZX81+34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; File:ZX81+35 REV 2.2.pdf a coloured version is here: File:ZX81+35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
10 January 2016
23 January 2016
The .JPG can be downloaded here; File:ZX81+35 rev2.2 - Bill Of Materials.pdf and the .ODF spreadsheet here: File:ZX81+358 rev2.2 Bill Of Materials.ods
31 January 2016
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
its a great milestone! And I'm glad I got it working, before the launch of the Raspberry PI 3 :-) . Not that I'm satisfied, its still far from a state in which I would be completely satisfied with it. To start with the keyboard is not wired up correctly, (see entry 2 February 2016 for that) and on top of that not all keys are working, in fact it was a struggle to produce the "hello world" text ("hallo world" actually) you see in the picture below. Also I was not satisfied with the black letters on a white background, the letters were very "thin" and hard to read, so I jumpered the board up to produce white text on a black background, as you can see in the picture below (sorry the picture is a bit fuzzy, cheap camera).
- keyboard connector that is compatible with the original ZX81, and can take its connectors.
- the video/sync combiner was modified to give a clean and compatible composite video signal.
- pin 15 of U9 (shift register 74HC165) connects to GND not CLK, which is more logical and clean.
- Wired the RCA connector correctly with pin 2 on GND and signal on pin 1
- Changed T8 to a faster PMEG2005 transistor for better picture quality
here is the updated .PDF, further updates are likely: File:ZX81+35 REV 3.0.pdf
I also saw that the interface was often splitting this signal into two separate pulses. Using LTSPICE, I added a first odd harmonic to the signal, and so managed to re-create the signal I saw, which I fed to the interface. And I could indeed observe how the signal was split into two pulses, amazingly the ZX81 (clone) could still load the file! It seems (from interpreting the Z80 code) that the ZX81 does not count the number of pulses in a burst, but merely counts the total high time to determine if a 0 or 1 was sent, so its more or less impervious to this problem, which doesn't mean I don't want to solve it! So I tweaked the circuit to see if I could make it less sensitive to signals "with a dent in it", after a lot of experimenting, (I had not much faith I would succeed) I found that the amazingly simple solution was to increase R59 from 4K7 to 10K, bravo for LTSPICE! So I made that change on my prototype, and indeed loading became more reliable. So I updated the schematic. In fact I'm still not completely satisfied with it, but further improvements would involve adding (zero crossing) analog logic, a comparator or opamp circuit. It could be that such a circuit is in the ULA of the ZX81, but I doubt it, at least in the ZX80 the signal was input directly into a LS367 buffer input. For a moment I considered simply replacing the circuit with a single gate LS type buffer, but I would get the same notorious insensitive audio input that the original ZX81 had, so no thanks!
