ZX81PLUS35 ZX81 clone
Project ZX81+35 ZX81 clone
My clone of the Sinclair ZX81
Contact Mahjongg
Last Update 2016-03-30
Some history about why I wanted to but it can be found here: [2]
As for now comments and questions on the design can be made here [3] (raspberry PI forum off topic section)  :-)
Introduction to the ZX81+35
3D Preview of early ZX81+34
Schematic 81+34
Layout ZX81+34
Keyboard for ZX81+34/35
The final ZX81+34
Starting the assembly
Finished assembly
Testing (continued)
ZX81+34 version TWO
Here is the new schematic revision 2.1: A .PDF of the new schematic can be found here: Bestand:ZX81+34 rev 2.1.pdf
3D preview version 2
Version 2.1
Version 2.2 (ZX81+35)
To make a long story short I indeed accepted that the line counter should be synced with intack, not kept pending for the duration of VSYNC like my earlier version, that also meant I had to re-think the logic for HSYNC and porch generation. While doing that I discovered my earlier porch logic was faulty (used the low nibble, instead of the high nibble of the counter), anyway the new logic should generate a sixteen cycle HSYNC signal sixteen cycles after the intack, and the back porch lasts 16 cycles after that. Here is a .PDF of the latest schematic, revision 2.2; Bestand:ZX81+35 REV 2.2.pdf a coloured version is here: Bestand:ZX81+35 REV 2.2 color.pdf.
29 DECEMBER 2015
30 December 2015
5 January 2016
Here is the latest preview, seen from the front of the board, the picture is fully updated, and also includes the planned ZX81+35's expansion board.
10 January 2016
23 January 2016
The .JPG can be downloaded here; Bestand:ZX81+35 rev2.2 - Bill Of Materials.pdf and the .ODF spreadsheet here: Bestand:ZX81+358 rev2.2 Bill Of Materials.ods
31 January 2016
Well, the PCB for revision 2.2 of my ZX81 + 35 (35 years after the launch of the ZX81, and almost exactly a year after version 1.0) was finally ordered, and I got an e-mail from Eurocircuits with a preview of the PCB, which I don't want to keep from you.
2 February 2016
new layout for rev 2.3:
new schematic for rev 2.3:
Bestand:ZX81+35 REV 2.3.pdf
21 February 2016
Here's the snapshot.
28 February 2016 It's alive!
I completely re-wired the keyboard, the previous wiring was completely wrong, and impossible to repair, so I ripped it out, and started again, it was quite a challenge to wire it up correctly, but I did, and now the keyboard is fully working (except the ground for the LEDs seems flaky, as they do tend to go off at the slightest vibration, probably a bad contact somewhere, but the keyboard now seems reliable. With the keyboard fully working, I was able to write some test code, that revealed some strange flukes. somehow white on black text is okay, perhaps a bit bold, but black text on white background is hard to read, as not much black is shown, it seems black pixels are narrower than white pixels. this needs more testing. Also printing characters above chr$(127) corrupts the screen (sync errors).
I updated the schematic with the different updates and patches I found so far:
here is the updated .PDF, further updates are likely: Bestand:ZX81+35 REV 3.0.pdf
The joystick interface worked, in that (with 2N7002 FETs) the joystick movements up, down, left, right and fire did indeed generate the relevant keyboard presses 5, 6, 7, 8 and 0, but except for left the arrow key functions (the 5 key with shift pressed) the other arrow functions were not correctly registered, so editing became impossible, as you could not do a "cursor up" or "cursor down". somehow the presence of the FETs caused this problem. As cursor left still worked it was determined that the total "load" of the four transistors (even when they were off) was a problem, as the four transistors connected to the not working arrow functions were all connected to the same address KBA12 line. probably the cause was gate-source capacitance of the FETs caused a small timing error because of capacitive loading of KBA12. after some deliberation I decided to replace the 5 FETs with 5 fast NPN Transistors, (I choose MMBT3904 transistors) and tried them (beginning with just one) and they worked! The joystick reliably simulate a closure of the 5,6,7,8 and 0 key, and there are no bad side effects. Luckily I added a series resistor R28, so this was possible. Updated the .PDF, will later update the layout.
March 27 2016 designed a well working cassette input port
This seemed to work very well, but in fact I saw that when I used a longer sequence of bursts C1 charged up, and after the last pulse the output level did not return to zero immediately, so I increased C1 to 10uF, its possible that lowering C1 would have also worked, but it would have made the circuit less sensitive. Also, putting an 1K terminating resistor on the input also helped with the same problem, and it would also be a good idea to put a small cap over the input to reject HF pulses. In any case this is what the simulator thought that would happen when a stream of eight pulses would be presented at the output, followed by silence:
The reason was obviously that the 10uF capacitor slowly started charging up. The solution would be to decrease the value of that cap, enough so that it would discharge in the time between two pulses, and further discharge in the 1300uS between two bits. A discharge path was already provided through resistors R79, R58, and R59, [4]. After some time of experimenting with capacitor values, and audio input levels, (higher levels would widen the pulse width of especially the last pulse) I decided that 4n7 was the optimal value, 1nF would make the circuit almost insensitive, and 10nF would make the last pulse excessively wide.
The "little bird" now tells me that this circuit should work fine, and it should also work with "turbo load circuits". I found several upload programs that can "play" .P files, one of which that uses a turbo load concept, I will patch my ZX81+35 prototype, and try to load some more files, until I'm satisfied the cassette interface works okay. Then I will try creating saving files to an audio recorder, and loading these recordings back. The layout has not changed.
I can Confirm that loading even longer programs works fine. If you set the volume a bit louder you can also load files in a propriety turbo charging format. Next up saving files.
